Help Please
ronthefordfan
  • New Member
  • Member For: 11y 11m 2d
Hi guys I'm having trouble with my g6et. The missus was driving this morning and it started running very ruff and wouldn't go much over 30ks. I started the car tonight and it's running ruff as guts.
I don't have a boost gauge on it but it seems like it has no boost at all. Could my actuator be stuffed and causing it to run like this. Last night I squirted wd40 in the boost solenoid, could I have stuffed something then.
The car has been tuned with I'd injectors cai and f6 cooler. I have installed a pwr stepped cooler and walbro in tank pump just last week, it's booked in for a new tune on Wednesday with hi flow cat.
Everything has been fine till today.
  • Moar Powar Babeh
  • Member For: 19y 2m 21d
You really shouldn't be driving it around after a fuel pump/cooler install without a return.
Since the last mod done was fuel pump and symptoms sound fuel pressure related I'm going to go with fuel hose issue on the pump. Ie split or loose
  • New Member
Oh also I checked the codes and it came up with p1000 and p1260. If it was fuel pressure wouldn't it bring up some code for that.
I thought the in tank replacement pump was fine to do without a retune, and we have been really babying it putting around.
  • New Member
Thanks for your help, I pulled the pump out today and sure enough the hose was split. Good as gold now
