Peak Power To Rpm
gaz097
  • Bronze Donating Members
  • Member For: 11y 9m 5d
319 @ 162kph - 4550 on a Mainline
  • Member For: 10y 7m 3d
319rwkw @ 5475 rpm
Ignore the figure below, that is their "flywheel" figure, the actual figure is only 319
Edited by rollex
Everyone's rpm is a lot higher then mine. Guess I have some flow issues up high.
Not necessarily, you are making 460rwkw, you would still be making way more power than any of us at 6k, eg you are flowing fine. The reason you are making peak power lower is because you are reaching the max flow of the head/cams/turbo so it is choking up top, it is still flow very well up top though.
If your power was 350kw etc I might comment that it was just your boost curve is poor and dropping off in the top end, but 460kw is definitely going to be stretching the flow limits of everything so it sounds normal.
edit: If you overlayed your dyno curve with ours you will see what I mean, your power in the high revs will still be very high, you are just making sh*tloads more torque (probably lots of boost) hence the low figure. What turbo are you running?
Edited by rollex
