  • Member For: 16y 7m 6d
Have to admit, im surprised it was cnv. They did my ba a few years back and it was awesome. I hadnt heard anything bad about them before (I have been away for 4 years though so anything is possible) hope its all good now mate.
  • Member For: 12y 2m 15d
Nah I havent had time to see mechanic.. going to take it on on monday... keep u guys updated
Edited by delacruz_xr6t
Next week going to put in valve springs and coils... any ideas what valve springs to buy... crow cam, plazmaman?
Do I need to but the retainers?
  On 10/03/2015 at 2:34 AM, camo86T said:
CMS supplied me with plazmaman
Apparently original retainers are fine
How much did they charge you?
  • Member For: 14y 9m 2d
I had my ba ute tuned at cv around 2yrs ago. first time it came out running 308kw @ 19psi and had a bad idle. took the car back and they lowered the boost to 15psi which raised the power to 325kw and said there's a problem with plugs or coils. Had a look myself turned out to be a huge air leak on the intake manifold. Got a new tuner now
Mine was 10lbs and 291rwkw and I said no more than 280 (4 speed auto) they said they couldnt get it any lower..
  • Member For: 11y 3m 26d
Have to check the invoice, but from memory they were $800-850 fitted
  • Member For: 14y 7m 19d
Tuner should start with the tune and go over it to make sure anything is okay, then they should be able to diagnose the issue, whether it be plugs, coils, valve springs etc.
Also I'm no expert but if valve springs are starting to hurt, im under the impression you could actually just put a decent exhaust on instead and free up exhaust flow and that will take some pressure off the valve springs and they might be okay. Plus you will make more power with it
