Fg F6 Springs Onto Fg G6E Turbo
wagondad
  • New Member
  • Member For: 10y 3m 13d
I can pick up a full set of FG F6 springs and shock's that have done 25000km for $250. I know after market springs and shocks will be far better but for the price plus I can fit them, and have a slight upgrade. Main question is regarding the ride height, how much lower are the F6's and I assume the springs and shocks will be rated slightly more towards performance. Cheers.
post-80683-0-57873900-1424563859_thumb.j
  • New Member
Thanks man, By the looks of your pic they are the same ride height, might still be worth getting just for the better handling, all be it not as good as after market but for the price worth the effort I think.
  • Member For: 10y 8m 15d
Ha ha these are mine that I think you're talking about, and I was the one who bought the F6 shocks for my G6E. Since sold the G6E and bought an F6, but swapped the suspension out of the F6 for Bilsteins. The F6 were definitely lower than the G6E shocks, about 15-20mm I think, plus my G6E had done nearly 100,000kms so I noticed a big increase in performance probably because the old shocks were worn out. If you can do it yourself then its a worthwhile change as the labour is what kills you normally.
  • New Member
I left it to late mate, didn't have the cash until this weekend, the listing is no longer there on Gumtree. Thanks for the reply.
  • New Member
Well springs and shocks are fitted, a lot easier than I expected, thanks to all the guides people posted.
I can confirm that the ride height for G6E T and F6 are identical 370mm front and back, the springs for the rear are the same 047-044 AA so I didn't change them over.
Front springs are shorter and thicker but end up at same ride height. No spring compressor required.
G6E Springs front - white and yellow dot. Shocks - L F488X.
F6 Springs front - white and red dot. Shocks - D D2B8 A.
G6E Springs Rear - 047-044 AA. Shocks - K F488X.
F6 Springs Rear - 047-044 AA. Shocks - Z D2B8 A.
