Window Washer - Fault
karlp2
  • Member For: 11y 6m 21d
Hi,
Hoping someone can help with this one... the window washer has stopped working in my FG falcon. The wipers still work, I can't seem to hear the washer motor at all. I've checked the fuse and that is fine - didn't really think it was that as the wipers are on the same fuse and they go. Plenty of water in the resoir.
Any ideas of what to check next? Or is this one for the auto electrician to sort? Cheers for your help.
Edited by karlp2
  • Member For: 10y 11m
Gday mate it will be the rubber filter on the pump in the bottle, you have to remove the inner guard liner to access. Pull pump out of the bottom of the bottle you will see the filter, remove and clean.
Thanks for that, will give that a try. Cheers.
  • Member For: 11y 9m 13d
If you cant hear the pump noise as you press trigger...it will prob be dead pump
How many kms?
I just got mine changed as it fuked up at 112,500kms
Theres a thread on the other forum about cleaning the filter (as mentioned above remove front passenger side wheel arch lining...access pump and remove/clean).
If still doesn't work then probably the pump!
Edited by PTR_NITRO_FG
  • Member For: 19y 9m 19d
Yeah if there's no noise then most likely dead pump.
Just get a genuine one, and it's an easy fix pulling out the the old one and replacing it.
Just remove some of the plastic screws in the the inner passenger side wheel arch and its right there.
  • Member For: 21y 6m 6d
If you can hear the pump then open the bonnet and remove the line at the T piece and blow through the fcker with your mouth to unblock the sh*t in the line.
  • Member For: 12y 12d
^doesn't work if the filters blocked up with algae like mine was. I could blow down the tube and hear the tank bubbling but still the pump was too weak to suck water through. Had to fully disassemble and clean/ bleach tank and filter
  • Bronze Donating Members
  • Member For: 11y 11m 3d
Sounds like my washer bottle problem but I decided not to 'blow' anything and instead bought a new pump $15...cheap just then. Ill install it tomorrow
Edited by BenDoCo
