  • Member For: 11y 3m 4d
bizket , I have so far - 1000 bosh injectors - build tail shaft for 600 plus hp -turbo side and battery relocation -half build BTR box with au parts and au pump - true track diff with 3.9 diff gears -nizpro cooler ,etc
thanks barnz will find out a bit of info about it
bizket , if I say jump of a cliff would you do it ? no you would not ,.so stop saying that I do not listen to the comments people say . I am listening ,but will pick and juice what I like .
  • Bronze Donating Members
  • Member For: 13y 9m 12d
  On 10/03/2015 at 11:31 AM, gunna said:
just have send a message to him thanks . how would this engine go running at 600 hp ? the cams are they huge ,obviously have to be for that sort of power
do not know what boost it will need to have 600 hp on pump 98 fuel ?
You would be coming into the range of them cams. Your converter will help u a little. I would imagine a flat 22psi thru the 4sp on 98 at about 5k would be about 450kw. With that motor you could run more boost down to make it more exciting to drive but your auto builder would hate it.
he has not replied to my message ? so I have just bought a FG long motor with turbo and intake manifold and throttle body plus some of the accessories like air con and power steering pump .it also has all the pulleys and belt tensioner .the engine has only travelled 6000 klm so is is just run in .the whole lot delivered to my door is about $3900-$4000
  • Like 3
  • Member For: 11y 5m 12d
f*ck yeah!!! I'm literally clapping right now.
Sell the turbo with your old rear housing for 500, cheering. Are you just doing oil pump gears and springs?
so FPT are tuning it, low k fg long sorted. This is going to turn out well for sure, could there be enough in the budget for something other than a btr now?
Edited by barnz
  • Like 2
  • Too heavy needs boost
  • Member For: 11y 8m 27d
how high is the cliff?
  • Like 2
  • Carnage on the Garage Floor
  • Member For: 14y 11m 21d
I'd be talking to Tony Bellert and get him to build you an engine to suit your budget Gunna.
barnz ,thinking of a 6 speed manual maybe . he has got one with the engine for a reasonable price . Jamie is going to do the tune to it
bomber ,thanks but have just bought the engine and paid a deposit .
bizket , Niagara falls sounds good .lol
Edited by gunna
just talked to the guy and he would do me a deal on the box and motor .extra $1700 for the box . what do I have to do to get it to work with my computer (the gearbox ?) I know I would have to get the tails haft re done to suit the manual . what about the gearbox mounts ? and what type of clutch would I need ?
etc ?
  • Member For: 20y 9m 10d
Dont know how to get the gearbox to work, but your going to need a bigger/better turbo. That engine sounds the goods and much cheaper than building from scratch. Is the owner on here?
