genuine honest person Member 2,769 Member For: 11y 3m 3d Gender: Male Location: near brisbane Posted 14/02/15 10:43 AM Author Share Posted 14/02/15 10:43 AM I will take a good look when I have it disassembled (turbo ). down time is no problem as it is not a daily driven car ,just a toy .thanks for your reply ,will think about that Link to comment https://www.fordxr6turbo.com/forum/topic/90082-engine-re-build/page/2/#findComment-1530200 Share on other sites More sharing options...
gaz097 Bronze Donating Members 1,752 Member For: 13y 9m 10d Posted 14/02/15 10:53 AM Share Posted 14/02/15 10:53 AM 6500 is about right. I built mine for 4500 myself using a spool kit plus oil pump gears , valve springs plus new plugs, coolant, gaskets, etc. The engine builder won't really do that much. All they will do is bore, deck the block, balance rotating assembly, machine crank if going under size or measure and fit 1 thou under bearings. Then check all clearances such as ring end gap etc. They really over charge in something they do every day for a living. 1 Link to comment https://www.fordxr6turbo.com/forum/topic/90082-engine-re-build/page/2/#findComment-1530203 Share on other sites More sharing options...
genuine honest person Member 2,769 Member For: 11y 3m 3d Gender: Male Location: near brisbane Posted 14/02/15 11:23 AM Author Share Posted 14/02/15 11:23 AM who reconditioned your head ?and how much was it .thanks Link to comment https://www.fordxr6turbo.com/forum/topic/90082-engine-re-build/page/2/#findComment-1530205 Share on other sites More sharing options...
gaz097 Bronze Donating Members 1,752 Member For: 13y 9m 10d Posted 15/02/15 10:34 AM Share Posted 15/02/15 10:34 AM I bought a head of a low Kay motor that bent a rod. I took the gamble on it being fine and so far so good. Link to comment https://www.fordxr6turbo.com/forum/topic/90082-engine-re-build/page/2/#findComment-1530357 Share on other sites More sharing options...
ratter Member 6,793 Member For: 18y 11m 4d Gender: Male Location: @ my laptop Posted 15/02/15 10:57 AM Share Posted 15/02/15 10:57 AM a patch up job is not a complete rebuild, an engine builder may dummy fit the engine 3 or 4 times before final assembly, there is time involved getting things to the correct thousands of an inch 1 Link to comment https://www.fordxr6turbo.com/forum/topic/90082-engine-re-build/page/2/#findComment-1530365 Share on other sites More sharing options...
gaz097 Bronze Donating Members 1,752 Member For: 13y 9m 10d Posted 15/02/15 11:04 AM Share Posted 15/02/15 11:04 AM A good builder should get it right the first time he goes to assemble it. 1 Link to comment https://www.fordxr6turbo.com/forum/topic/90082-engine-re-build/page/2/#findComment-1530367 Share on other sites More sharing options...
gaz097 Bronze Donating Members 1,752 Member For: 13y 9m 10d Posted 15/02/15 11:07 AM Share Posted 15/02/15 11:07 AM And I did. I measured all clearances and selected bearings and what not to The required tolerance.The heads on these things are not known for failure and even the atomic motors run standard heads unless u spend the big dollars for upgraded valves Link to comment https://www.fordxr6turbo.com/forum/topic/90082-engine-re-build/page/2/#findComment-1530369 Share on other sites More sharing options...
ratter Member 6,793 Member For: 18y 11m 4d Gender: Male Location: @ my laptop Posted 15/02/15 11:12 AM Share Posted 15/02/15 11:12 AM yep, we all live in a perfect world don't we and the heads do need reconditioning from time to time and should be part of a proper rebuild, a patch up is a patch up, no matter who tries to convince us it's a full rebuild 1 Link to comment https://www.fordxr6turbo.com/forum/topic/90082-engine-re-build/page/2/#findComment-1530370 Share on other sites More sharing options...
gaz097 Bronze Donating Members 1,752 Member For: 13y 9m 10d Posted 15/02/15 11:17 AM Share Posted 15/02/15 11:17 AM That's why we have measuring tools like micrometers and such so u yet stuff right the first time. Heads always will require a reco and 90% of the time it's a visual inspection and a clean if it's in good working order. Link to comment https://www.fordxr6turbo.com/forum/topic/90082-engine-re-build/page/2/#findComment-1530372 Share on other sites More sharing options...
A1 Automotive New Member 11 Member For: 10y 4m 9d Posted 16/02/15 08:53 AM Share Posted 16/02/15 08:53 AM Where do you calibrate your eyes for a visual inspection? Heads need more than a visual inspection, especially if your building an engine, very least it should be pressure tested/hardness tested, I've always got my valve seats and valves cut, ideally a new set of valves in a perfect world. 2 Link to comment https://www.fordxr6turbo.com/forum/topic/90082-engine-re-build/page/2/#findComment-1530508 Share on other sites More sharing options...
