BenDoCo I'm getten too old for this s**t Bronze Donating Members 4,509 Member For: 12y 27d Gender: Male Location: A big bridge over a river in South Australia Posted 15/02/15 12:52 AM Share Posted 15/02/15 12:52 AM (edited) Dear Car Gods.........I have but one wish.I wish people would understand that when a light on the Dash comes on, it means that the engine is running well outside its normal parameters and the vehicle should be stopped, the engine turned off and a tow truck called.-------------------Unless you have stripped down, worked on, machined and rebuilt a buttload of engines then there is little chance of you seeing/identifying possible problems and damage that a 2 minute drive with the oil light on will cause.Find an 'expert' to do this please otherwise in the near future, damage that should have been rectified but was over looked may come back to bite you in the arse.-----------Actually Car Gods............I heard that you were working on a hand that comes out of the dash and slaps the crap out of the driver when a light comes on............how's that coming along???? Edited 15/02/15 12:56 AM by BenDoCo 1 Link to comment https://www.fordxr6turbo.com/forum/topic/90081-engine-failure/page/3/#findComment-1530264 Share on other sites More sharing options...
ratter Member 6,793 Member For: 18y 11m 7d Gender: Male Location: @ my laptop Posted 15/02/15 01:04 AM Share Posted 15/02/15 01:04 AM yes, running any length of time with a warning light on can lead to an even emptier bank account, turning it off at the fist flicker may have saved you thousands of dollars 3 Link to comment https://www.fordxr6turbo.com/forum/topic/90081-engine-failure/page/3/#findComment-1530270 Share on other sites More sharing options...
Bizkets is Drunk? Too heavy needs boost Member 5,929 Member For: 11y 8m 28d Gender: Male Location: Adelaide Posted 15/02/15 01:04 AM Share Posted 15/02/15 01:04 AM (edited) Don sounds like someone is board. LolHows that turbo going. Dusted it lately. Edited 15/02/15 01:04 AM by Bizkets is fat? Link to comment https://www.fordxr6turbo.com/forum/topic/90081-engine-failure/page/3/#findComment-1530271 Share on other sites More sharing options...
"Captain Retard" Member 1,417 Member For: 11y 1d Gender: Male Location: Shellharbour NSW Posted 15/02/15 01:32 AM Share Posted 15/02/15 01:32 AM What people have to understand is without oil pressure there is nothing to stop metal touching metal.Oil is a barrier that separates your engines moving parts.Once there's no oil then metal touches metal and heats up and pretty quickly the surface hardness has come off and turned into a wonderful grinding paste which can then affect other parts that may have otherwise survived.No oil pressure is very bad, even if it's only seconds.Remember 2000rpm = crank turning over 33 times per second.What little oil was in the bearings has soon either burnt off or heated up so much that it's lost its viscosity and run out of the sides due to centrifugal force of the crank spinning.Very very very bad 1 Link to comment https://www.fordxr6turbo.com/forum/topic/90081-engine-failure/page/3/#findComment-1530274 Share on other sites More sharing options...
"Captain Retard" Member 1,417 Member For: 11y 1d Gender: Male Location: Shellharbour NSW Posted 15/02/15 01:46 AM Share Posted 15/02/15 01:46 AM I will also add that the oil is under high pressure so it actually forces the moving parts apart so that they are actually floating.But that oil film is very thin.The oil has to also keep being replaced as it heats up very quickly due to its own friction.Very bad, very very bad Link to comment https://www.fordxr6turbo.com/forum/topic/90081-engine-failure/page/3/#findComment-1530275 Share on other sites More sharing options...
weavel New Member 19 Member For: 10y 4m 21d Posted 15/02/15 01:48 AM Author Share Posted 15/02/15 01:48 AM Will update tomoro thanks for all the responses and feedback. Not looking the best after some of the responses fingers crossed still Link to comment https://www.fordxr6turbo.com/forum/topic/90081-engine-failure/page/3/#findComment-1530276 Share on other sites More sharing options...
turbotrana Member 2,586 Member For: 22y 1m 3d Gender: Male Posted 15/02/15 04:15 AM Share Posted 15/02/15 04:15 AM On 15/02/2015 at 12:52 AM, BenDoCo said: I wish people would understand that when a light on the Dash comes on, it means that the engine is running well outside its normal parameters and the vehicle should be stopped, the engine turned off and a tow truck called.Rubbish, if a red light comes on, it means rev the engine up and drive it as much as you can to see if the red light goes off 3 Link to comment https://www.fordxr6turbo.com/forum/topic/90081-engine-failure/page/3/#findComment-1530296 Share on other sites More sharing options...
weavel New Member 19 Member For: 10y 4m 21d Posted 16/02/15 06:40 AM Author Share Posted 16/02/15 06:40 AM UpdateHi torque stripped engine down bottom end is 100% fine. Needs cylinder head replaced bent some valves stems, snapped timing chain and one of the cams threw off its groove n bored into its guide. Total cost $3500Still not the best scenario but could have been a lot worse hope she runs good for here on out as I like the vehicle but if any else goes wrong the missus will force a sale Thanks for help everybody was a learning curve for me Link to comment https://www.fordxr6turbo.com/forum/topic/90081-engine-failure/page/3/#findComment-1530475 Share on other sites More sharing options...
barnz Member 3,047 Member For: 11y 5m 14d Gender: Male Location: Brisbane Posted 16/02/15 07:01 AM Share Posted 16/02/15 07:01 AM (edited) Have you green lighted the top end rebuild yet?A bf/fg donor could be sourced for that money that have stronger rods amongst other things. 2nd hand engines are obviously an unknown quantity. So is a ba bottom end though... Edited 16/02/15 07:04 AM by barnz Link to comment https://www.fordxr6turbo.com/forum/topic/90081-engine-failure/page/3/#findComment-1530479 Share on other sites More sharing options...
weavel New Member 19 Member For: 10y 4m 21d Posted 16/02/15 07:11 AM Author Share Posted 16/02/15 07:11 AM Yeh gave the go ahead don't wanna mess around anymore, though had a couple lined up if necessary. Vehicle is a 2005 bf early model though Hi torque have good feedback so putting my trust in them Link to comment https://www.fordxr6turbo.com/forum/topic/90081-engine-failure/page/3/#findComment-1530482 Share on other sites More sharing options...
