weavel New Member 19 Member For: 10y 4m 19d Posted 13/02/15 10:03 PM Share Posted 13/02/15 10:03 PM (edited) So story goes Got a bc early model 420rwhpGave it a stab the other night too of second gear oil light came on, backed offStill sounded fine idled fineCruised bout 1 km to pick up kidsWhen turned car back on engine and oil light onOnly bout 2 kms home so I putter along won't let me rev above 2500Power cuts off stop car wait ten minsHoo back in starts n idles fine figure I'll put home40k/h bam loud metal rattle sounds like timing chain is just ripping teeth car shuts off. DoneTry to start up get that horrible timing chain noise won't turn over. I think oil pump fail engine starving for oilEngine getting pulled apart on Monday to access damageAnybody got an idea what I mite b looking atHopefully just timing chain no serious damageCurrently quoted 6-8 Hun to strip engine 4k for semi rebuild 6-8 for full rebuild do these figures sound right?If rebuild I will get a spool import kitAny responses or help is greatly appreciated Edited 13/02/15 10:04 PM by weavel Link to comment https://www.fordxr6turbo.com/forum/topic/90081-engine-failure/ Share on other sites More sharing options...
weavel New Member 19 Member For: 10y 4m 19d Posted 13/02/15 10:07 PM Author Share Posted 13/02/15 10:07 PM If I acquired my own kit from spool what would b reasonable labour cost? And I currently have a live tune will that still be running n operative? Link to comment https://www.fordxr6turbo.com/forum/topic/90081-engine-failure/#findComment-1530080 Share on other sites More sharing options...
Wilko16 Donating Members 1,672 Member For: 17y 5m 10d Gender: Male Location: Melbourne Posted 13/02/15 10:56 PM Share Posted 13/02/15 10:56 PM No good to hear that mate, definitely not gonna be good if you have heard metal crunchingBest and cheapest method for a new motor is to buy a FG F6 bottom end, which has forged Pistons and good for 400killer wasps Can be bought for $2500 off ebay But if your head has been damaged or it was starved of oil you will nearly need a whole new motor and turbo In that case it will be easier to buy a smashed car or a whole motor There is one on eBay at the moment for $5000 I think 1 Link to comment https://www.fordxr6turbo.com/forum/topic/90081-engine-failure/#findComment-1530086 Share on other sites More sharing options...
genuine honest person Member 2,769 Member For: 11y 3m 3d Gender: Male Location: near brisbane Posted 14/02/15 12:15 AM Share Posted 14/02/15 12:15 AM just had some prices on getting a engine build . from $6500- $12,000 plus depending on how good you want it build .I am going for the cheaper option . it has still got good parts in it to handle more than 500 rwkw 1 Link to comment https://www.fordxr6turbo.com/forum/topic/90081-engine-failure/#findComment-1530094 Share on other sites More sharing options...
weavel New Member 19 Member For: 10y 4m 19d Posted 14/02/15 12:21 AM Author Share Posted 14/02/15 12:21 AM On 13/02/2015 at 10:56 PM, Wilko16 said: No good to hear that mate, definitely not gonna be good if you have heard metal crunchingBest and cheapest method for a new motor is to buy a FG F6 bottom end, which has forged Pistons and good for 400killer wasps Can be bought for $2500 off ebay But if your head has been damaged or it was starved of oil you will nearly need a whole new motor and turbo In that case it will be easier to buy a smashed car or a whole motor There is one on eBay at the moment for $5000 I thinkNo major metal grinding or banging just the timing chain noise. All the noise is coming from directly at the front. Was still idling fine and purring like a kitten otherwise I wouldn't have kept putting along.It's was only running dry for prob 2 ks is that far enough to do serious damage?Thanks for the response mate will know Monday once they pull it apart what the damage is. Fingers crossed Link to comment https://www.fordxr6turbo.com/forum/topic/90081-engine-failure/#findComment-1530096 Share on other sites More sharing options...
weavel New Member 19 Member For: 10y 4m 19d Posted 14/02/15 12:27 AM Author Share Posted 14/02/15 12:27 AM On 14/02/2015 at 12:15 AM, gunna said: just had some prices on getting a engine build . from $6500- $12,000 plus depending on how good you want it build .I am going for the cheaper option . it has still got good parts in it to handle more than 500 rwkw $6500 sounds reasonable. Spool import sellin rebuild kits for like $2300. It's goin into hi-torque at Gold Coast. They reckon anywhere for 4k to 8k depending what needs replacing. Would love it to just need a timing chain kit hahhahahha I guess if I gotta rebuild it I may as well do it right n boost it up a bit afterwards It's was getting 420rwhp on only 11psi would b good to see what 16-18psi would net meThanks for the response mate Link to comment https://www.fordxr6turbo.com/forum/topic/90081-engine-failure/#findComment-1530100 Share on other sites More sharing options...
Wilko16 Donating Members 1,672 Member For: 17y 5m 10d Gender: Male Location: Melbourne Posted 14/02/15 12:33 AM Share Posted 14/02/15 12:33 AM Hopefully it's something simpleJust remember if you wanting to up the power (as all of us do) Then you need to factor in making everything else stronger 1 Link to comment https://www.fordxr6turbo.com/forum/topic/90081-engine-failure/#findComment-1530102 Share on other sites More sharing options...
weavel New Member 19 Member For: 10y 4m 19d Posted 14/02/15 12:36 AM Author Share Posted 14/02/15 12:36 AM On 14/02/2015 at 12:33 AM, Wilko16 said: Hopefully it's something simpleJust remember if you wanting to up the power (as all of us do) Then you need to factor in making everything else strongerYeh I'm hearing u. It's got brake upgrade. Heavy duty twin plate clutch. N new pedders suspension all round. Let's see if I can snap a drive shaft hahhahahha Link to comment https://www.fordxr6turbo.com/forum/topic/90081-engine-failure/#findComment-1530103 Share on other sites More sharing options...
weavel New Member 19 Member For: 10y 4m 19d Posted 14/02/15 12:36 AM Author Share Posted 14/02/15 12:36 AM Yeh wilk u got a link to fg bottom end $2.5k ? Link to comment https://www.fordxr6turbo.com/forum/topic/90081-engine-failure/#findComment-1530104 Share on other sites More sharing options...
cano1 New Member 3 Member For: 12y 9m 17d Posted 14/02/15 12:39 AM Share Posted 14/02/15 12:39 AM http://m.ebay.com.au/itm/GENUINE-FORD-FG-TURBO-F6-XR6-TYPHOON-FPV-Short-Motor-BRAND-NEW-/271543583788 1 Link to comment https://www.fordxr6turbo.com/forum/topic/90081-engine-failure/#findComment-1530107 Share on other sites More sharing options...
