  • Member For: 12y 2d
Is it a gain from going from the f6 with a gt3582 already to a gtx3576, or are you picking up quicker spool. I pondered over a gtx3576 and gtx3582 when I just had mine tuned.And the tuner steered more towards the gtx3582,and I ended up with the gtx3582.Overall on e85 I love it,im going to switch over to 98 today to feel the difference.maybe speak to your preferred tuner.
  • RNS10S
  • Member For: 18y 8m 8d
You will gain a little over the GT3582r but will benefit a heap due to the earlier spool.
If you can afford some wide wheels and grippy tyres there wouldn't be many cars that would worry you on the street.
  • Like 2
  • Bronze Donating Members
  • Member For: 13y 9m 3d
  On 05/03/2015 at 11:29 AM, Butt Plug said:
Hahaha no a 82 is not good for 30psi ever its well out of its efficiency range, will it do it ... Yeh so a stock turbo can cram 40psi of wasted heat into a engine if u want but why would u want that ?
A GTX76 is smacking it at around 25psi on e85 and will destroy alot of parts along the way hence why tuners wont do it as it creates a huge torque rush
A 76 in hard n fast is the ultimate street set up imho
All I read was huge torque rush. Sounds like the goal.
  • MattyP
  • Cruise Control
  • Member For: 12y 11m 20d
I wouldn't be too worried about going over to the gtx
The 3582 is almost identical to the gtx3582r. If you put a billet wheel on it you'll have the potential for mid 400s on e85 and with better spool
Edit
Gtx3576r for ultimate street weapon
Edited by MattyP
Edit
I couldn't ring any more then 20psi and a gay boost curve for 430 out of the stock turbo. Gtx is much stronger.
