(Locky) Member 85 Member For: 11y 22d Gender: Male Posted 30/01/15 05:19 AM Share Posted 30/01/15 05:19 AM Just after a heads up if there is anything I need to look out for in putting new leaf springs in the back of my ute.Pretty mechanical but just never done anything with solid rear ends before.I have the springs which have a front bush already installed, along with some new nolathane ones for the rear which look to be easily pushed in with hand tools.One question is the car seems to have 2 possible mounting positions for front bush. Do I just use the highest one like stock springs?Also the king springs seemed to come with a small strip of metal that looks to be a washer. Or will that make sense as where it goes when I get the old one out?Just checking is there anything I need to look out for to avoid it turning into a 8 hour job or getting car half pulled apart and something missing thanks Link to comment Share on other sites More sharing options...
OZYWALKER XR50T Gold Donating Members 2,795 Member For: 11y 8m 23d Gender: Male Location: Western Sydney Posted 30/01/15 05:56 AM Share Posted 30/01/15 05:56 AM Can only use original hole for the front spring as the other hole is only in the bracket not through the chassy. 1 Link to comment Share on other sites More sharing options...
genuine honest person Member 2,769 Member For: 10y 11m 27d Gender: Male Location: near brisbane Posted 30/01/15 06:51 AM Share Posted 30/01/15 06:51 AM one of the easiest jobs you can do your self mate . Link to comment Share on other sites More sharing options...
PhilMeUp Member 1,045 Member For: 16y 6m 8d Gender: Male Location: Perth, Western Australia Posted 30/01/15 07:21 AM Share Posted 30/01/15 07:21 AM I replaced the leaf springs on my BF ute a few weeks ago.Not particularly difficult. Get some new shackle bushes before you start the job. The Ford part number is XT5781A (Ford have been using them since the 1968 XT Falcon) or you can get Nolathane ones. You'll need 8 of them (4 each side).Some photos here: http://www.fordxr6turbo.com/forum/topic/89684-2006-fpv-tornado-f6-ute-cleanup-resurrection/#entry1520650 Link to comment Share on other sites More sharing options...
(Locky) Member 85 Member For: 11y 22d Gender: Male Posted 30/01/15 07:37 AM Author Share Posted 30/01/15 07:37 AM Yeah got the nolathane shackle bushes (wasnt sure on name, but the rear ones)Will these make sense once I have the old spring out?Also the king springs dont have the short spring with the bracket halfway along like stockIs that just a design difference and not to be worried about? Im quite competent ripping apart and putting back together my other car, but as this is the daily and need to tow something sunday I just want to make sure I wasnt missing something glaringly obvious so can hopefully get it smashed out Saturday arvo Link to comment Share on other sites More sharing options...
PhilMeUp Member 1,045 Member For: 16y 6m 8d Gender: Male Location: Perth, Western Australia Posted 30/01/15 10:15 AM Share Posted 30/01/15 10:15 AM (edited) It's all simple. Once you've done it then you'll wonder what all the fuss was about.Some photo guides (I can't find the equivalent threads on here): http://www.fordforums.com.au/showthread.php?t=11428368http://www.fordforums.com.au/showthread.php?t=11418260Check to make sure that the spare wheel winch works while you're there. Whenever unwinding or winding up the cable, make sure that there's always tension on it so that it doesn't jam up inside the casing. http://www.fordforums.com.au/showthread.php?t=11427506 Edited 30/01/15 10:21 AM by PhilMeUp Link to comment Share on other sites More sharing options...
(Locky) Member 85 Member For: 11y 22d Gender: Male Posted 30/01/15 10:33 AM Author Share Posted 30/01/15 10:33 AM ThanksIve had a peruse of your photo essays on here which helped clear some things up (like not to tackle wheel bearing at home unlike the IRS stuff ive done)Those loose washer/spacer things that came with the springs is only thing im concerned about now 1 Link to comment Share on other sites More sharing options...
genuine honest person Member 2,769 Member For: 10y 11m 27d Gender: Male Location: near brisbane Posted 30/01/15 10:55 AM Share Posted 30/01/15 10:55 AM I do not know what they are for ? my rear leafs did not have them .they were not king but john bowe specials .I can not understand where they would fit Link to comment Share on other sites More sharing options...
PhilMeUp Member 1,045 Member For: 16y 6m 8d Gender: Male Location: Perth, Western Australia Posted 30/01/15 11:32 AM Share Posted 30/01/15 11:32 AM I had trouble removing the rear discs on my FPV ute recently. I spent ages thumping them with a hammer but they still wouldn’t come loose.In the end I fed the brake caliper bolts through the caliper mounts until they pushed the disc off a little bit. Rotate the disc half a circle and repeat.http://www.fordforums.com.au/showpost.php?p=5278853&postcount=36 Link to comment Share on other sites More sharing options...
FiftyOne Bronze Donating Members 1,145 Member For: 11y 6m 23d Gender: Male Posted 30/01/15 11:40 AM Share Posted 30/01/15 11:40 AM If I'm not mistaken, you just jack the back up & unbolt the leafs? No need to compress/decomp the pack like front coils? Link to comment Share on other sites More sharing options...
