Bomber Carnage on the Garage Floor Donating Members 3,994 Member For: 15y 16d Gender: Male Location: Gold Coast Posted 28/01/15 09:28 AM Share Posted 28/01/15 09:28 AM E85 is the logical choice or porting the head and changing cams but that's big $$$ for not much return with the little GTX. Would love to see someone do it though. Link to comment https://www.fordxr6turbo.com/forum/topic/89984-what-mods-after-the-gtx3576/page/2/#findComment-1526362 Share on other sites More sharing options...
Chaos310 Donating Members 228 Member For: 12y 8m 26d Gender: Male Posted 28/01/15 12:24 PM Share Posted 28/01/15 12:24 PM more boost? you've got everything to do it by the sounds of it... Link to comment https://www.fordxr6turbo.com/forum/topic/89984-what-mods-after-the-gtx3576/page/2/#findComment-1526399 Share on other sites More sharing options...
julesk_1972 Member 267 Member For: 12y 10m 2d Gender: Male Location: Perth Posted 28/01/15 01:24 PM Share Posted 28/01/15 01:24 PM Chart with pressures? Link to comment https://www.fordxr6turbo.com/forum/topic/89984-what-mods-after-the-gtx3576/page/2/#findComment-1526403 Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,332 Member For: 19y 8m 4d Gender: Male Location: Perth Posted 28/01/15 01:27 PM Share Posted 28/01/15 01:27 PM If not e85 a small nos shot or methanol/water injection. Link to comment https://www.fordxr6turbo.com/forum/topic/89984-what-mods-after-the-gtx3576/page/2/#findComment-1526404 Share on other sites More sharing options...
PAH Donating Members 361 Member For: 16y 4m 8d Gender: Male Posted 28/01/15 08:17 PM Author Share Posted 28/01/15 08:17 PM (edited) Hi Guys,I have a dyno chart in hard copy format. Spiro sent me a soft copy but I can't find it and apart from that, my connection to this forum stops me from attaching files or copying and pasting text! And I have no doubt that Spiro has set the boost to its optimum level.I a Datsun with an after-market turbo many years ago. It used water injection to enable it to run 9lb of boost on the old pink Super fuel we burned back then. How is methanol set up these days? What gains does it offer? Aquamist sells kits but there may be cheaper ways to set up methanol injection. Thanks for the info on E85. I envisaged E85 cars burning only this fuel. It's still a less than optimum solution as (I would imagine) it involves running the tank just about empty before an E85 refill - and E85 remains hard to find. I wonder if a variable geometry turbo is available and if it would produce a broader power band? Wikipedia has a page on this topic.PAH Edited 28/01/15 08:20 PM by PAH Link to comment https://www.fordxr6turbo.com/forum/topic/89984-what-mods-after-the-gtx3576/page/2/#findComment-1526426 Share on other sites More sharing options...
sixman Donating Members 601 Member For: 20y 10m 5d Gender: Male Location: Hills District, NSW Posted 28/01/15 09:10 PM Share Posted 28/01/15 09:10 PM Seriously look at the precisions. PTE6235 will bolt on without requiring any major mods, then just need a retune. Spiro got 450rwks on mine with 98ron, still a conservative/safe tune. Or look at the 6466 with smaller rear housing for quick spool and even more power. Link to comment https://www.fordxr6turbo.com/forum/topic/89984-what-mods-after-the-gtx3576/page/2/#findComment-1526431 Share on other sites More sharing options...
demon1300 Member 435 Member For: 13y 3m 18d Gender: Male Posted 29/01/15 09:58 AM Share Posted 29/01/15 09:58 AM Forget the PTE and Garrett, just go straight for an EFR Borg Warner. They're the best by far when it comes to outright power and good spool. They are megga pricey though and can be difficult to fit. Highly worth looking at if your into changing turbos.Sent from my Nexus 5 using Tapatalk Link to comment https://www.fordxr6turbo.com/forum/topic/89984-what-mods-after-the-gtx3576/page/2/#findComment-1526611 Share on other sites More sharing options...
sixman Donating Members 601 Member For: 20y 10m 5d Gender: Male Location: Hills District, NSW Posted 29/01/15 11:27 AM Share Posted 29/01/15 11:27 AM Agree borg warner is best and most expensive. Only worth doing if starting from scratch as will need new dump pipe, intake etc. If you have allready done everything else the precisions and garrets are bolt on. Link to comment https://www.fordxr6turbo.com/forum/topic/89984-what-mods-after-the-gtx3576/page/2/#findComment-1526636 Share on other sites More sharing options...
bjc Donating Members 2,823 Member For: 21y 8m 23d Gender: Male Location: Townsville Posted 29/01/15 11:44 PM Share Posted 29/01/15 11:44 PM Biggest thing with water/meth setups these days is using a quality pump with high pressure (200psi) and rated for methanol use not just water. Also quality nozzle's to fine mist at high pressure.As for more power I would probably change your intake to a bigger turbo side intake for best flow possible and buy quality tyres that will hold ALL your power from take off as the tyres seem to be the biggest thing most people scrimp on after power upgrades!Get all the skidding and tyre smoking out of your system first then change to an extremely grippy tyre...As for water/meth it is an excellent chemical power adder and cooling system and from memory with regards to chatting with my tuner he mentions generally 3 degrees (or more?) of timing can be added when using the injection. This is in the Nth Qld so I'm not sure what gains would be available to you as temperatures are totally different (mainly humidity). Link to comment https://www.fordxr6turbo.com/forum/topic/89984-what-mods-after-the-gtx3576/page/2/#findComment-1526723 Share on other sites More sharing options...
MattyP MattyP Cruise Control 6,317 Member For: 13y 23d Gender: Male Location: Central Coast Posted 30/01/15 01:20 AM Share Posted 30/01/15 01:20 AM E85 bud if you are in the Sydney region just get it My car swaps all the time Just make sure you run it almost dry Link to comment https://www.fordxr6turbo.com/forum/topic/89984-what-mods-after-the-gtx3576/page/2/#findComment-1526734 Share on other sites More sharing options...
