Worth The Cash?
Cjafpv
  • Member For: 10y 7m 10d
Hey guys my f6 is currently sitting at 315rwkw with just a dump pipe cat and tune
Have been quoted slightly over 11k for the following
* PW stage 2 cooler kit
* battery relo and turbo side intake
*finish of the exhaust with stainless catback
* 1000cc injectors kpm
* kpm twin 300 bolt In fuel system
* wastegate porting 12psi actuator
* zf trans service with syntrans oil
* valve springs and retainers
* cold thermostat
* turbo smart Bov
* custom tune
Now I think the quote is quite a fair price for what is going to be done and I'm assuming the car will make close to the 380rwkw mark my question is guys this is a lot of money for me 11k I can afford it thts not the issue the issue is I know the car will feel different but will it be 11k better if you know what I mean . I know it may sound silly but I'm just scared I'm
Gonna drop 11k and then not be so impressed with the result. I guess what I'm asking is Guys has anyone had similar power to what I currently have then gone up to what I'm looking at getting done and would anyone care to comment? :) thanks for the input guys. I guess this question sort of also stems from
The fact that a few people have sort of hinted to me that my car won't be much faster due to traction issues etc but part of my motivation for the mods is the sound and aggressive note and really the cooler has to be done as power really sucks on a hot day.
  • Too heavy needs boost
  • Member For: 11y 7m 3d
Go plazmaman cooler and cai and bat. Save a few dollars there over pw stuff. Surge is cheaper the the kpm drop in to. Xforce stainless cat back is cheap.
Also what shop is doing the mods and tuning?
  • Like 2
  • Member For: 11y 1m 9d
I know it all adds up fast . I only want 350-360 rwkw (have 312 rwkw ) need a dump pipe and cat $1000 . new valve springs (fitted )$850 . throttle relocation kit plus pipe work $500 ? new 12 psi actuator $180 and a re tune $800-$1000
now that is $3530 and I will do most of the work my self except for the tune and valve springs
  • Member For: 11y 3m 17d
The kpm twin in tank is an expensive option if your goal isn't 700kw
Good setup for e85 though and you would make more power if its a viable option
Also manual or auto? Can probably factor in a box if zf if your going to start pushing 400
Edited by barnz
  • Member For: 10y 10m 7d
Most important thing is the TUNER!
Do your homework and read up on what tuners in your state have the best reputations.
It's all here in this forum so spend a bit of time going thru the threads.
Dropping 11k on mods you need a good Tuner and you owe it to yourself to avoid any heartbreak.
Good luck
  • Like 2
  • Member For: 12y 6m 8d
If it was me, I'd do the things in Blue.
plus look for someone flicking a PW surge tank, you can get them reasonably priced second hand. A single pump unit will be ok if you dont want to go crazy.
The stock intake, with a muffler delete will make good power and retain a stock look. leave the stock BOV, its money you dont need to spend. Dont do the airbox or battery relo, again, money you dont need to spend. just bore a 100mm hole in the lower half front of your stock air box. also look for someone reverting their build to stock or upgrading for cheaper parts if you're watching a budget, if you know what you are looking at/for damage wise, abused etc.
My f6 (manual) went 387kw with turbo gate, injectors, exh, stage 2 PW cooler, 12lb actuator and a small 400 walbro equipped surge tank (no HP from surge, just cheap insurance) BUT like the others say, it all comes down to your tuner.
My .02c
* kpm twin 300 bolt In fuel system <----------------
* cold thermostat
* turbo smart Bov
* custom tune
  • Like 3
Sounds like the initial job was done on the cheap. Just saying
What makes you say it was done on the cheap? I thought at the time 310rwkw-320rwkw which is what tuner said car would make would be enough power and didn't want anymore but as usual I've gotten use to it and want more. At the time tuner was honest and said thts all I need for low 300's
