Fg Xr6 Turbo
jacobmitchell92
  • Waiting for the 1st N/A 12!
  • Member For: 17y 1m 30d
  On 07/05/2015 at 9:33 AM, jacobmitchell92 said:
Cheers guys. Still has a little left in it. Will be trying some stuff out. Hopefully they let me in again!!
Sent from my iPhone using Tapatalk
Awesome effort bud and good to see Rob getting some faster cars coming out recently!!!
What sort of changes are you talikng about??? Hardware or Software wise?
These 66mm GTX mods seem pretty good of late... even seen one make over 550 recently...
  • Member For: 13y 11m 30d
He sure is! Pumping out some decent cars.
Bit of both. Few things we want to change in the tune engine and gear box. But have ordered a new turbo for it as well. But that'll take a while.
The 66mm wheel has put 2 of his cars into the 9s now. And mine made 535rwkw with it but we pulled it back as it was out of its efficiency range. And run it down the track with 505rwkw.
Don't know if I'll get down to the track again this season due to work etc.
Yea mad mine was around the 500 -520 mark when I ran my 9,,, got more power since (last time out ran 145 mph) but track wasn't there and I just spun through 2nd...
I've Rob for quite some time now and he's a top bloke...
Good luck with your new set up and bring on the mid to low 9s I say....
  • Hench, but no longer shredded or tanned.
  • Member For: 18y 13d
But isnt it all about making that max figure even if its over 6k rpm????? /s
Back to back 9s is an amazing effort.. Credit to the car and driver.
Edited by AzMahoony
Nope I change gear around the 5k mark and it only sees over 6k in 4th gear at the end of the strip. More power will give you a higher et. But you need to consider the way it's been delivered. In our case we were concentrating more on the launch ie 60ft time. Hence the et was slightly lower than everyone else in the 9s.
Thanks mate ran solid all night. Drove to and from the track and did a HJs run on the way home. Only thing that was changed was the slicks. Apart from that everything is how it is normally driven on the street.
  • 2 months later...
