  • XR50T
  • Member For: 12y 7d
New good quality bands don't fall apart at random intervals.
No guarantee they won't leak without some gasket put in between the V flanges.
Also new clamps usually have a shorter bolt so are a pita without a huge set of multi grips to get the nut on the bolt.
  • Member For: 12y 8m 11d
yep, flanges over V-band. if the exhaust is made correctly in the first place, you should not need the adjustment that comes with v band. It just complicates things due to all the adjustment. Its just as easy to put a few bolts in a flange than clamp up a v band. Actually, maybe easier.
Although, I have a mate with an X-force full 4". His flange at the cat sticks out a lot. The v band in my Nizpro at the cat is much better for ground clearance. So maybe that's a plus.
  • XR50T
There's F all adjustment in the nizpro system. The flanges have to be lined up perfectly to seal properly or it sounds farked.
  • Bronze Donating Members
  • Member For: 12y 1m 1d
  On 17/01/2015 at 8:55 AM, ratter said:
I would rather deal with flanges than V bands
+1
  • Member For: 12y 10m 1d
Have heard Clearence can be better with V bands.
  • 3 years later...
  • Member For: 12y 6m 27d
my xforce 4 inch turbo back turned up today for an fg ute.
bloody big pipe.
hopefully goes on without any bullsh*t modifications.
good to hear other peoples experience.
  • Member For: 10y 3m 9d
  • Gender: Not Telling
  On 20/08/2018 at 8:21 AM, ba6turbo said:
bloody big pipe.
Expand
That's what she said... Hur hur hur :prankster:
I've got a different brand 4 inch dump and it hits the steering column heat shield. Carnt of a thing to get in and out as well but it does the job.
