RB Snake Donating Members 327 Member For: 11y 5m 2d Gender: Male Location: Perth SOR Posted 11/01/15 09:07 AM Share Posted 11/01/15 09:07 AM Hi guys, I have a strange issue(?) with my ZF. After coming out of a corner and accelerating to 50-60kmph it seems to hold 3rd gear and sit at about 3000+rpm after I let off the throttle, even if I take my foot of totally it still holds gear, I have to just tap/hold the pedal in lightly then it'll switch gear.I've been reading up a little bit on this and have found that the ZF has a low tolerance to uneven/mismatched front tyres. Apparently this makes the gearbox think that the car is turning a corner. I dunno how true this is or how the ZF can even work this out, but I do have mismatched tyres on the front end (had a screw in one, it needed to be replaced asap, they didn't have the same tyre in stock). So I'm thinking this might be the cause. Before I get rid of both the front tyres has anybody else come across this issue? Link to comment https://www.fordxr6turbo.com/forum/topic/89902-zf-holding-gears/ Share on other sites More sharing options...
Bulletime Donating Members 937 Member For: 14y 4m 15d Gender: Male Posted 11/01/15 09:57 AM Share Posted 11/01/15 09:57 AM I've never read about it being worried about mismatched tyres! If your gunning it what's probably happening is its thinking your going to keep going and its leaving it in a lower gear waiting to go faster. In performance mode it's more obvious otherwise it may have learned you like to go hard. Once you get to third she'll be so willing just to keep going, the fg xr6 turbo just wants to keep going and if you gas it up and then hold back it'll be left wanting.That's my 2c anyway, I would t sorry unless your putting around then you might just to reset it by disconnecting the battery in case it's learnt some bad habits. 1 Link to comment https://www.fordxr6turbo.com/forum/topic/89902-zf-holding-gears/#findComment-1522702 Share on other sites More sharing options...
MattyP MattyP Cruise Control 6,317 Member For: 13y 20d Gender: Male Location: Central Coast Posted 11/01/15 10:00 AM Share Posted 11/01/15 10:00 AM Its in limp mode mate Link to comment https://www.fordxr6turbo.com/forum/topic/89902-zf-holding-gears/#findComment-1522703 Share on other sites More sharing options...
discostig Manual mode ________________________ All day, erryday Donating Members 13,798 Member For: 17y 5m 29d Gender: Male Location: Probably above atmospheric pressure Posted 11/01/15 10:20 AM Share Posted 11/01/15 10:20 AM (edited) As bulletime said, giving it a bit of a flog makes it hold the gear, expecting another hit. Basically it thinks you're on a race track and about to enter another corner. When you touch throttle again it realises you're not and then allows an upshift.Solution?Manual modeAll DayErryday Edited 11/01/15 10:21 AM by -Stever- 3 Link to comment https://www.fordxr6turbo.com/forum/topic/89902-zf-holding-gears/#findComment-1522711 Share on other sites More sharing options...
MattyP MattyP Cruise Control 6,317 Member For: 13y 20d Gender: Male Location: Central Coast Posted 11/01/15 10:27 AM Share Posted 11/01/15 10:27 AM My gearbox was holding 3rd after some really heavy launches with the standard heat exchanger Wouldn't shift into anything else. Found out that's limp mode Link to comment https://www.fordxr6turbo.com/forum/topic/89902-zf-holding-gears/#findComment-1522713 Share on other sites More sharing options...
Bizkets is Drunk? Too heavy needs boost Member 5,929 Member For: 11y 9m 18d Gender: Male Location: Adelaide Posted 11/01/15 10:30 AM Share Posted 11/01/15 10:30 AM Mine does the same. Its norm. The box holds gear in drive after wot and if you do not accelerate again it will change after 2-3 seconds. Link to comment https://www.fordxr6turbo.com/forum/topic/89902-zf-holding-gears/#findComment-1522714 Share on other sites More sharing options...
MattyP MattyP Cruise Control 6,317 Member For: 13y 20d Gender: Male Location: Central Coast Posted 11/01/15 10:32 AM Share Posted 11/01/15 10:32 AM Oh man I read that wrong My badJust the Zf thinking your hooning and holds the gear for max funnessMy apologies 1 Link to comment https://www.fordxr6turbo.com/forum/topic/89902-zf-holding-gears/#findComment-1522715 Share on other sites More sharing options...
BenDoCo I'm getten too old for this s**t Bronze Donating Members 4,509 Member For: 12y 1m 17d Gender: Male Location: A big bridge over a river in South Australia Posted 11/01/15 10:47 AM Share Posted 11/01/15 10:47 AM (edited) Mine does it every now and then as well.....when just pottering around like an old bloke....and it doesnt matter if I try the normal things to get it to change, it won't.If I notice it happening too much / to often, I'll connect up the xcal and re-tune it (coz my zf tuned) and that fixes it for a while.I'm positive that this is a part of my fuel usage problemsEditI'll just explain a bit moreSome times I could be doing 70 80 or 90 and it sits in 3rd like I have it in manual mode Edited 11/01/15 10:50 AM by BenDoCo Link to comment https://www.fordxr6turbo.com/forum/topic/89902-zf-holding-gears/#findComment-1522721 Share on other sites More sharing options...
Bizkets is Drunk? Too heavy needs boost Member 5,929 Member For: 11y 9m 18d Gender: Male Location: Adelaide Posted 11/01/15 11:01 AM Share Posted 11/01/15 11:01 AM Normal driving style. Floor it then brake. And repeat Link to comment https://www.fordxr6turbo.com/forum/topic/89902-zf-holding-gears/#findComment-1522723 Share on other sites More sharing options...
RB Snake Donating Members 327 Member For: 11y 5m 2d Gender: Male Location: Perth SOR Posted 11/01/15 11:17 AM Author Share Posted 11/01/15 11:17 AM Ah good to know it's not just mine. I'll reset it disconnect the battery and hopefully it'll re-learn my habits.It doesn't really happen when I'm flogging it, just normal acceleration not in performance mode. It's kinda weird because the first to second shift is ok but then in third it just keeps on revving. If I ever flog it I change gears myself. Link to comment https://www.fordxr6turbo.com/forum/topic/89902-zf-holding-gears/#findComment-1522727 Share on other sites More sharing options...
