Ctyjet Member 72 Member For: 13y 5m 20d Posted 28/12/14 12:32 AM Share Posted 28/12/14 12:32 AM Looking at replacing the factory heat exchanger with an air cooling system to avoid the milkshake all together just wondering what is the best unit out on the market Link to comment https://www.fordxr6turbo.com/forum/topic/89815-zf-heat-exchanger/ Share on other sites More sharing options...
Skids4kids in the mid....not the bum like some Member 609 Member For: 12y 17d Gender: Male Posted 28/12/14 01:40 AM Share Posted 28/12/14 01:40 AM The ZF kit from furious Performance is the go and removes the chance of ever having a milkshake.He does one with or without a fan all plug and play.Don't forget to top the ZF up have a litre handy to do so. Link to comment https://www.fordxr6turbo.com/forum/topic/89815-zf-heat-exchanger/#findComment-1519492 Share on other sites More sharing options...
arronm Dropping a turd Gold Donating Members 9,520 Member For: 17y 6m 14d Gender: Male Location: Perth Posted 28/12/14 01:50 AM Share Posted 28/12/14 01:50 AM Or fill the cooler and lines when you install it... Way easier Link to comment https://www.fordxr6turbo.com/forum/topic/89815-zf-heat-exchanger/#findComment-1519493 Share on other sites More sharing options...
RB Snake Donating Members 327 Member For: 11y 4m 18d Gender: Male Location: Perth SOR Posted 28/12/14 02:04 AM Share Posted 28/12/14 02:04 AM What about a PWR heat exchanger? They've been out a while now and no bad reports as of yet. With an air cooler it would probably not keep the oil temperatures as stable as the heat exchanger style does. Link to comment https://www.fordxr6turbo.com/forum/topic/89815-zf-heat-exchanger/#findComment-1519495 Share on other sites More sharing options...
arronm Dropping a turd Gold Donating Members 9,520 Member For: 17y 6m 14d Gender: Male Location: Perth Posted 28/12/14 02:07 AM Share Posted 28/12/14 02:07 AM that's what I fitted and recommend. PWR heat exchanger Link to comment https://www.fordxr6turbo.com/forum/topic/89815-zf-heat-exchanger/#findComment-1519496 Share on other sites More sharing options...
xr6tForMe Donating Members 275 Member For: 11y 10m 11d Gender: Male Posted 28/12/14 02:14 AM Share Posted 28/12/14 02:14 AM I think the PWR replacement is probably the best.I think it will operate closer to "factory" specs.I personally bought a much cheaper "oil to air" type kit for the ZF and mounted it in front of the radiator on my car using another kit which had things like "zip tie sticks".I will see if I can find links to what I used and post them later. 1 Link to comment https://www.fordxr6turbo.com/forum/topic/89815-zf-heat-exchanger/#findComment-1519498 Share on other sites More sharing options...
Ctyjet Member 72 Member For: 13y 5m 20d Posted 28/12/14 02:17 AM Author Share Posted 28/12/14 02:17 AM Just figured with the cost of one and still not completley eliminating the chance I thought air would be a better option and more affordable 1 Link to comment https://www.fordxr6turbo.com/forum/topic/89815-zf-heat-exchanger/#findComment-1519499 Share on other sites More sharing options...
ratter Member 6,793 Member For: 18y 11m 13d Gender: Male Location: @ my laptop Posted 28/12/14 02:31 AM Share Posted 28/12/14 02:31 AM Something to think about, almost every automatic car ever produced has used an oil to water cooler, how many have problems? Link to comment https://www.fordxr6turbo.com/forum/topic/89815-zf-heat-exchanger/#findComment-1519500 Share on other sites More sharing options...
ratter Member 6,793 Member For: 18y 11m 13d Gender: Male Location: @ my laptop Posted 28/12/14 02:32 AM Share Posted 28/12/14 02:32 AM Something to think about, almost every automatic car ever produced has used an oil to water cooler, how many have problems? Link to comment https://www.fordxr6turbo.com/forum/topic/89815-zf-heat-exchanger/#findComment-1519501 Share on other sites More sharing options...
Ctyjet Member 72 Member For: 13y 5m 20d Posted 28/12/14 03:00 AM Author Share Posted 28/12/14 03:00 AM What about this style furious exchanger would this just replace the oem one and is it better? Link to comment https://www.fordxr6turbo.com/forum/topic/89815-zf-heat-exchanger/#findComment-1519503 Share on other sites More sharing options...
