MattyP MattyP Cruise Control 6,317 Member For: 12y 10m 9d Gender: Male Location: Central Coast Posted 27/12/14 11:28 PM Share Posted 27/12/14 11:28 PM Ah nice I'm sure you'll get increased response compared to us big A2A guys Link to comment Share on other sites More sharing options...
Lennox Member 2,586 Member For: 12y 15d Gender: Male Location: Perth Posted 28/12/14 12:21 AM Share Posted 28/12/14 12:21 AM (edited) Oops baby posted sorry Edited 28/12/14 12:22 AM by Lennox Link to comment Share on other sites More sharing options...
barnz Member 3,047 Member For: 11y 3m 21d Gender: Male Location: Brisbane Posted 28/12/14 12:59 AM Share Posted 28/12/14 12:59 AM (edited) Cost, complexity, weight.For most road applications, front mounted air-air is more than sufficient.With water-air you need two heat exchangers (rather than one) fluid and a fluid drive.As for response... modern hi-end/hi-po road cars now feature software filters to dampen throttle response. Running shock torque loads into the contact patches, especially before weight transfer has occured, is bad for grip and chassis stability, which is fine if you are inducing instability in order to generate agility, but, not so fine if you are tooling around on the road.Turbo threshold and lag (what lag there is left these days) can be your friend in road situations where grip is marginal, such as on wet roads.Agree with everything except lag on a wet road being your friend. Power multiplication in a very short rpm range, ie significantly increasing your output in a few hundred rpm as the boost starts to ramp it, breaks sh*t, and in the case of wet weather its traction, violently. I think id rather have the quicker response and do my best to modulate so as not to upset the balance of the car rather than having to use alot of throttle, have it all of a sudden explode like a stick of dynamite and have to roll out very sharply and try modulate wheel spin.You can see this in effect by using a higher gear coming out of a corner. Where you should use say second use third and push the throttle hard(in the wet). I guarantee there will be a point where all hell suddenly breaks loose. Where as second would have indeed been sketchy also but more predictable and controllable.Just my own observations from experience. Edited 28/12/14 01:01 AM by barnz Link to comment Share on other sites More sharing options...
aiboart Member 665 Member For: 20y 1m 26d Posted 28/12/14 11:00 AM Share Posted 28/12/14 11:00 AM Modulating something is fine provided that you have the skill and attention to deal with the situation.On a more fundamental level, where two systems interact (say car and driver) and the control system response is slower than the action of the slave system, the potential exists to create a negative feedback loop; the control system first overshoots and then it overcompensates...then it overshoots.... Link to comment Share on other sites More sharing options...
xr6tForMe Donating Members 273 Member For: 11y 8m 12d Gender: Male Posted 28/12/14 11:28 AM Author Share Posted 28/12/14 11:28 AM Aiboart. While I understand what you are saying, I don't think it is terribly relevant here.You could just as easily say "More power has downsides (eg fuel consumption and parts breakages) so you should not mod your car for more power". That would also be correct in some people's opinions, but probably not the general population of this forum. How often has a turbo car owner (more specifically, someone on this forum) said "I wish my car was less responsive" and how often do they say "I wish my car was more responsive"? Link to comment Share on other sites More sharing options...
BRK Member 361 Member For: 13y 3m Gender: Male Location: Perth Posted 29/12/14 02:17 AM Share Posted 29/12/14 02:17 AM The WTA cooler debate - interesting. As best as I can undertsand it, the whole game is aimed to have minimal restriction in the air intake system coupled with the intake air charge entering the engine at ambient temperature (or lower). If you are going to the trouble of introducing a fluid based cooling system to reduce the temperature of the aircharge, then why not work out a way of lowering the charge temperature with chilled water via a refridgerated system? Not taking the p*ss here but that would be the best outcome. Certainly a serious engineering problem given the design limitations of the car but maybe ??? possible.Or maybe........ the financial strain of xmas has wrecked what's left of my brain? Link to comment Share on other sites More sharing options...
MattyP MattyP Cruise Control 6,317 Member For: 12y 10m 9d Gender: Male Location: Central Coast Posted 29/12/14 02:31 AM Share Posted 29/12/14 02:31 AM Liquid nitrogen would work well.... Link to comment Share on other sites More sharing options...
OZYWALKER XR50T Gold Donating Members 2,795 Member For: 11y 10m 12d Gender: Male Location: Western Sydney Posted 29/12/14 02:40 AM Share Posted 29/12/14 02:40 AM Best W2A setup I've seen on a falcon is the Snort Performance Ice-man liquid plenum. But it's made for the EA-AU falcon.Would be pretty sweet to see a similar setup for the B Series or FGs. 1 Link to comment Share on other sites More sharing options...
MattyP MattyP Cruise Control 6,317 Member For: 12y 10m 9d Gender: Male Location: Central Coast Posted 29/12/14 03:03 AM Share Posted 29/12/14 03:03 AM Not really that street able Liquid nitrogen is way more practical as nitrogen is everywhere Link to comment Share on other sites More sharing options...
xr6tForMe Donating Members 273 Member For: 11y 8m 12d Gender: Male Posted 29/12/14 11:59 AM Author Share Posted 29/12/14 11:59 AM MattyP, Have you been reading this http://homemadeliquidnitrogen.com/ ?? It is quite interesting. Link to comment Share on other sites More sharing options...
