Why No Water To Air Intercoolers?
xr6tForMe
  • Member For: 11y 6m 10d
I am wondering why water to air intercoolers are not more popular on on Barra engines?
If one was mounted over the top of the engine (like the top mount intercooler on the territory), it would get rid of a whole lot of piping volume which would have to be good for response.
  • Member For: 19y 11m 24d
Cost, complexity, weight.
For most road applications, front mounted air-air is more than sufficient.
With water-air you need two heat exchangers (rather than one) fluid and a fluid drive.
As for response... modern hi-end/hi-po road cars now feature software filters to dampen throttle response.
Running shock torque loads into the contact patches, especially before weight transfer has occured, is bad for grip and chassis stability, which is fine if you are inducing instability in order to generate agility, but, not so fine if you are tooling around on the road.
Turbo threshold and lag (what lag there is left these days) can be your friend in road situations where grip is marginal, such as on wet roads.
I see people discussing which (expensive) aftermarket turbo to fit and they are often concerned about response/lag. People specifically WANT response.
I would not think that cost and complexity is too much worse when people are already spending large amounts of time/money on modifying their cars.
They are already rearranging batteries, air filters, replacing all piping, replacing intercoolers, cutting parts of the car to fit massive intercoolers etc, etc.
One extra radiator and pump does not seem like too much more.
  • Member For: 12y 7m 13d
It's because they wont sell well.
Most XR6T drivers are not after response but just tyre frying power and noise.
It's much more complex to design and engineer a water to air intercooler kit than it is to make a battery side intake kit. The majority of XR6T owners are not going to pay thousands more for a Water to Air when air to air models exist because if any manufacturer were to make one they would barely make any decent profits for their time and effort spent developing the kit.
Edited by Z2TT
  • MattyP
  • Cruise Control
  • Member For: 12y 8m 5d
And in we are forgetting about one important thing here guys
Heat soak
If mounted on top of the engine (like most are) you get really terrible heat soak. That's why I ditched the WTA on my celica to a fmic. I didn't lose that much response either and my IAT were lower than with a WTA
  • Bronze Donating Members
  • Member For: 11y 9m 2d
Was just gunna mention Heat Soak.
One of my mates in the 4wd club up here runs water/air and even on a 3litre turbo diesel it suffers badly so I would say that under the bonnet of our cars - probably wouldn't be too good
MattyP,
Was the WTA cooler on your Celica a standard factory item?
If so: Had you modified the parameters it was operating under? (more boost/heat to deal with)
And: Are factory coolers ever good enough for enthusiasts?
In any case, I think engine bay heat is just an issue to consider in designing the system, rather than an insurmountable problem.
Some possible things to do to help with this would be
-placement of the cooler to the side so it is not directly above the hot engine
-insulate the cooler from the engine bay (eg exhaust wrap tape)
-insulate the exhaust keep heat in and kepp the engine bay cooler (again exhaust wrap tape)
-ensure enough water flow to remove heat added from the engine bay
-ensure enough heat removed from the water by the radiator section of the system
  • MattyP
  • Cruise Control
Yes that is correct
And all those things you've listed are pretty spot on
But once again time, money, effort and reward I don't think it's worth it IMO
Fmics cool easier, and are less complicated and usually cheaper.
If you feel like tackling a WTA than go for it. Would be very interesting to see the results
