JETURBO ...JD TUNING ADELAIDE... Gold Donating Members 23,708 Member For: 17y 7d Gender: Male Location: Adelaide Posted 31/12/14 09:32 AM Share Posted 31/12/14 09:32 AM Hahaha holey chit mate 15psi on stall is on the up side there and hence why your busting stuff As a very "flimsy" rule 8-10 psi with stock driveline is about it at the strip with sticky tryes and good for 1.7's with everything in 1 piece 9 times out of 10 hahaha Link to comment https://www.fordxr6turbo.com/forum/topic/89802-kens-g6e-turbo/page/3/#findComment-1520336 Share on other sites More sharing options...
kgcG6ET New Member 16 Member For: 11y 1m 18d Gender: Male Posted 31/12/14 01:05 PM Author Share Posted 31/12/14 01:05 PM Driveline isn't standard. Strengthened flexplate, rebuilt zf gearbox by Monsta Torque - increased stall on torque convertor, capable of handling 750kw, Hardie Spicer Chrome Moly tailshaft, LSD and HD halfshafts. 1 Link to comment https://www.fordxr6turbo.com/forum/topic/89802-kens-g6e-turbo/page/3/#findComment-1520391 Share on other sites More sharing options...
Bizkets is Drunk? Too heavy needs boost Member 5,929 Member For: 11y 10m 1d Gender: Male Location: Adelaide Posted 31/12/14 01:17 PM Share Posted 31/12/14 01:17 PM Still 15lb is a bit. Link to comment https://www.fordxr6turbo.com/forum/topic/89802-kens-g6e-turbo/page/3/#findComment-1520395 Share on other sites More sharing options...
JETURBO ...JD TUNING ADELAIDE... Gold Donating Members 23,708 Member For: 17y 7d Gender: Male Location: Adelaide Posted 31/12/14 11:37 PM Share Posted 31/12/14 11:37 PM What HD half shaft brand is that, u blew it to bits but it kind of looks like the stock item ? Was that before u installed the HD units ? Link to comment https://www.fordxr6turbo.com/forum/topic/89802-kens-g6e-turbo/page/3/#findComment-1520458 Share on other sites More sharing options...
kgcG6ET New Member 16 Member For: 11y 1m 18d Gender: Male Posted 01/01/15 01:21 AM Author Share Posted 01/01/15 01:21 AM The ODS HD halfshaft was the shaft that sheared off at the hub. The reason for the breakage could have been that the nut on the halfshaft hadn't been tightened correctly on installation and had come loose. I will explain my reasoning for this. Normally when I jack the rear of the car off the ground, it would be to change the wheels over to the M/T ET Radials. During this process, I leave the handbrake on. While replacing the broken halfshaft, I obviously had to release the handbrake and found by accident that the DS rear wheel wobbled side to side. Initially, I thought it maybe a bearing but on further investigation, I found that the haftshaft was loose. It took 2 full turns on the nut to tighten it up. If the ODS was the same, it could have been the cause of the breakage. The HD halfshafts were installed by an independent workshop. The HD halfshafts do not have a manufacturer marked on them. They were purchased from Prestige Auto Venue, Victoria. I was told they come from the US. The shaft is larger in diameter and the CV joints are stronger. The attached photos show the standard halfshaft compared to the HD halfshaft. 2 Link to comment https://www.fordxr6turbo.com/forum/topic/89802-kens-g6e-turbo/page/3/#findComment-1520491 Share on other sites More sharing options...
JETURBO ...JD TUNING ADELAIDE... Gold Donating Members 23,708 Member For: 17y 7d Gender: Male Location: Adelaide Posted 01/01/15 01:25 AM Share Posted 01/01/15 01:25 AM (edited) Hate to BRAKE it to ya but the look like repco items Been there done that bud and yeh there an up grade but dont have nothing on the "DRIVELINE SHOP 1400hp" half shafts These are slightly better than stock and do not recommend 15psi stall or ull be in the same boat again Edited 01/01/15 01:27 AM by Butt Plug Link to comment https://www.fordxr6turbo.com/forum/topic/89802-kens-g6e-turbo/page/3/#findComment-1520494 Share on other sites More sharing options...
kgcG6ET New Member 16 Member For: 11y 1m 18d Gender: Male Posted 01/01/15 01:33 AM Author Share Posted 01/01/15 01:33 AM Butt Plug have you had issues with your halfshafts and do you have the 1400hp shaft installed in yours? I did price them at one stage but they are not cheap. They would certainly be the way to go but I cannot justify the cost just yet. Link to comment https://www.fordxr6turbo.com/forum/topic/89802-kens-g6e-turbo/page/3/#findComment-1520502 Share on other sites More sharing options...
BenDoCo I'm getten too old for this s**t Bronze Donating Members 4,509 Member For: 12y 2m Gender: Male Location: A big bridge over a river in South Australia Posted 01/01/15 01:37 AM Share Posted 01/01/15 01:37 AM I guess you'd have to work out the cost of the cheaper ones by how many you may break on a 15lb launch and add it up to see if they're worth it 1 Link to comment https://www.fordxr6turbo.com/forum/topic/89802-kens-g6e-turbo/page/3/#findComment-1520504 Share on other sites More sharing options...
JETURBO ...JD TUNING ADELAIDE... Gold Donating Members 23,708 Member For: 17y 7d Gender: Male Location: Adelaide Posted 01/01/15 01:39 AM Share Posted 01/01/15 01:39 AM A question for you KGC How much u pay for the prestige auto ones ? Link to comment https://www.fordxr6turbo.com/forum/topic/89802-kens-g6e-turbo/page/3/#findComment-1520507 Share on other sites More sharing options...
kgcG6ET New Member 16 Member For: 11y 1m 18d Gender: Male Posted 02/01/15 08:27 AM Author Share Posted 02/01/15 08:27 AM (edited) The HD halfshafts cost $550 from Prestige Auto. The price of the Driveshaft Shop Fd26 Full Chrome Moly Level 5 Axle/Hub Kit - 1,400hp would cost $2,200 + $367 freight + Import Duty ($400+?) Edited 02/01/15 08:35 AM by kgcG6ET Link to comment https://www.fordxr6turbo.com/forum/topic/89802-kens-g6e-turbo/page/3/#findComment-1520775 Share on other sites More sharing options...
