pumpngo New Member 24 Member For: 10y 5m 17d Posted 26/12/14 08:00 AM Share Posted 26/12/14 08:00 AM I've been searching to find specs on the ba , bf , and fg turbo .From my search it seems ba bf are the same and fg is said to be a smaller turbo by some . Others say the turbines are the same on all 3. comp 61.4-82 trim56turb 68-84 It seems that the ba is comp .7 ar and turbine 1.06 ar and the fg is comp .5 ar and 1.06 turbine.So from all my searching I think they are both the same turbo but the fg just has the smaller ar on the compressor.Any help on exact specs appreciated as I have found so much conflicting info. 1 Link to comment https://www.fordxr6turbo.com/forum/topic/89800-ba-bf-and-fg-turbocharger-specs/ Share on other sites More sharing options...
bandblightfoot Member 183 Member For: 12y 4m 29d Gender: Male Location: Gold Coast Posted 26/12/14 08:11 AM Share Posted 26/12/14 08:11 AM Ba Bf gt3540 Fg gt3576. Fg spools quicker but runs out of puff approx 320rwkw after tune and supporting mods the f6 was fitted with the gt3540 hence more power more towards the 350rwkw region. Heaps of info on the forum if you look around don't know if this helps. Link to comment https://www.fordxr6turbo.com/forum/topic/89800-ba-bf-and-fg-turbocharger-specs/#findComment-1519287 Share on other sites More sharing options...
pumpngo New Member 24 Member For: 10y 5m 17d Posted 26/12/14 08:38 AM Author Share Posted 26/12/14 08:38 AM Yes I have found general info on one making more hp, or the other spooling faster, but not exact specs on ar or trim or inducer exducer diameters .If it's just me searching in the wrong place, could you point me in the right direction maybe I'm using the wrong questions .gtx3576r is in the turbo by garrett site but not gt3540 and I don't think the gtx is the right one . garett does not list exact specs for the ford turbo's , or I cant find them . Link to comment https://www.fordxr6turbo.com/forum/topic/89800-ba-bf-and-fg-turbocharger-specs/#findComment-1519288 Share on other sites More sharing options...
camo86T Silver Donating Members 1,810 Member For: 11y 3m 19d Gender: Male Location: SW Sydney Posted 26/12/14 09:58 AM Share Posted 26/12/14 09:58 AM (edited) Can't paste a link right now but if you go to the turbo section there's a pinned thread called "what is the std turbo in FG" or words to that effect - should helpTechnically correct name for 3540 as in our cars is 3582 which will be on the garrett website.All BA and BF models and FG F6 all have GT3582rFG xr6T has GT3576r which from memory is not a std garrett model(??)All these are 0.5AR with basically the same cover, just that 3576 has smaller ID intake to make 0.5AR with the smaller exducerTurbine is the same.Hope this helps Edited 26/12/14 10:00 AM by camo86T Link to comment https://www.fordxr6turbo.com/forum/topic/89800-ba-bf-and-fg-turbocharger-specs/#findComment-1519297 Share on other sites More sharing options...
pumpngo New Member 24 Member For: 10y 5m 17d Posted 26/12/14 10:13 AM Author Share Posted 26/12/14 10:13 AM It appears that the gt3576 fg turbo might be 76 comp as garett would imply but the ba turbo said to be gt3540 might be a gt3582 with 82mm comp and both might have the .5 ar housing. Would really like to know for sure from someone that has checked the sizes, as the huge amount of info on the net often conflicts. Link to comment https://www.fordxr6turbo.com/forum/topic/89800-ba-bf-and-fg-turbocharger-specs/#findComment-1519302 Share on other sites More sharing options...
camo86T Silver Donating Members 1,810 Member For: 11y 3m 19d Gender: Male Location: SW Sydney Posted 26/12/14 10:35 AM Share Posted 26/12/14 10:35 AM Correct, 3576 has 76mm od comp wheel / exducer, 3582 has 82mm...Like I said above, both have 0.5AR housing / cover, but 3576 has smaller intake internal diameter as it's got the smaller comp wheel. Both have 3" / 76mm outer diameter intake Link to comment https://www.fordxr6turbo.com/forum/topic/89800-ba-bf-and-fg-turbocharger-specs/#findComment-1519307 Share on other sites More sharing options...
PTR_NITRO_FG Donating Members 3,214 Member For: 12y 6d Gender: Male Location: NOR Perth Posted 26/12/14 10:45 AM Share Posted 26/12/14 10:45 AM I think all the pros are busy during the holiday period I think I read....GT3540r is the ford specific turbo 0.5 front cover...but is the same as GT3582r except the 3582 has 0.7 front cover?AFAIK...all the Fords have same rear housing with 1.06AR and 0.5 frontGTX versions of both turbos have 0.7 frontBut NFI the size of the bits inside I.e. referring to OP. that's where the pros should have more info...but I think the GT3576 has a smaller front wheel and therefore spools quicker? Link to comment https://www.fordxr6turbo.com/forum/topic/89800-ba-bf-and-fg-turbocharger-specs/#findComment-1519309 Share on other sites More sharing options...
camo86T Silver Donating Members 1,810 Member For: 11y 3m 19d Gender: Male Location: SW Sydney Posted 26/12/14 11:04 AM Share Posted 26/12/14 11:04 AM Yeah didn't explain that very well did I #coznotpro But 3582 on garrett site will give all the internal specs for ford spec 3540I have a pic somewhere of 3576 and 3540/3582 comp wheel side by side for comparison when I changed mine over but maybe I've done enough damage lol Link to comment https://www.fordxr6turbo.com/forum/topic/89800-ba-bf-and-fg-turbocharger-specs/#findComment-1519311 Share on other sites More sharing options...
pumpngo New Member 24 Member For: 10y 5m 17d Posted 26/12/14 11:12 AM Author Share Posted 26/12/14 11:12 AM Thanks with all your help and going back to garett with your info I think I have the specs straight now. Link to comment https://www.fordxr6turbo.com/forum/topic/89800-ba-bf-and-fg-turbocharger-specs/#findComment-1519312 Share on other sites More sharing options...
MattyP MattyP Cruise Control 6,317 Member For: 13y 27d Gender: Male Location: Central Coast Posted 27/12/14 08:25 AM Share Posted 27/12/14 08:25 AM 3540 is a 3582 in a .5 cover 3576 is a t04s/t04b 53mm inducer 76mm excuder in a t04e .5 cover.It is different to the other 3576 you may see on the Web for billet wheels as it has a different inducer. What you can do is use your fg turbo and put different compressor wheels/covers and make your own hybrid. That's what I'm doing Link to comment https://www.fordxr6turbo.com/forum/topic/89800-ba-bf-and-fg-turbocharger-specs/#findComment-1519397 Share on other sites More sharing options...
