  • Member For: 18y 10m 22d
Coils are wired and the car starts and runs a lot better. I fixed the exhaust leak that we had at the turbo/dump pipe v band. I decided to change the exhaust housing to a 1.15 while I was at it.
I also fitted the new billet thermostat housing and removed the header tank. It really opened up a lot of space...  Only a fuel line leak to fix and she'll be ready to hit the dyno again...
Edited by HI PSI
  • Like 7
  • XR50T
  • Member For: 11y 11m 15d
Loving the work as always mate, looking great.
All that steel braid though, would have been so many cuts and pricks lol. Its bastard stuff to work with. Pushlock hose 4TW haha
Thanks guys. Seldom get comments on my thread. Can't work out why...
I gets  a bit lonely talking to yourself...
Anyway....... Update.
I haven't been happy with the current remote steering reservoir for some time. I also need to fix some issues, so I decided to kill two birds with one stone. Literally.. The other is for the header delete.. It will be mounted on the l/h chassis, in front of the catch can.
Edited by HI PSI
  • Like 2
  • Member For: 13y 7m 14d
Wow, alot going on...
All the braid on the passenger side firewall looks like spaghetti... lol, More $$ in fittings and hoses then entire builds
Love the wrecker tag on the FG rocker cover for extra street cred.
Have you considered the billet MFP radiator mounts and a oil feed like bracket
It's a little messy on the l/h  side at the moment. As the rocker cover hasn't had the weld on fittings installed. The vacuum lines are a little messed up also, as I had to remove the reg and such, to fab a new reg bracket. This will delete the old pcm bracket that it is mounted to. I still have a lot to do, a lot of it make some carbon fiber parts. The car hasn't received any attention for many months as any spare time I have had, has been required elsewhere...
So, I have decided to come clean. I have be unfaithful...
It all started when I purchased this last Christmas. In the last few months, it has progressed somewhat. All at the expense of progress of the above...
Edited by HI PSI
  • Like 2
  • Sad 1
