HI PSI Member 1,589 Member For: 19y 3d Gender: Male Location: Central Queensland Posted 26/08/19 03:33 PM Author Share Posted 26/08/19 03:33 PM I have a few new carbon pieces in development - Seat backs, carbon subwoofer enclosure and an OTR cold air intake. When free time permits. I will post some pics as they are fabricated.... Also considering some carbon door cards to suit my SQ sound system.... But need more time off work....... If only... 2 Link to comment https://www.fordxr6turbo.com/forum/topic/89792-my-build/page/61/#findComment-1687744 Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,518 Member For: 17y 1m 18d Gender: Male Location: Melbourne Posted 26/08/19 03:59 PM Share Posted 26/08/19 03:59 PM always the problem... not enough time off work to spend your money (that's you, if you didn't guess)... but then when you've got enough time off work you don't have enough money to spend (that's me at the moment) Link to comment https://www.fordxr6turbo.com/forum/topic/89792-my-build/page/61/#findComment-1687748 Share on other sites More sharing options...
HI PSI Member 1,589 Member For: 19y 3d Gender: Male Location: Central Queensland Posted 26/08/19 11:10 PM Author Share Posted 26/08/19 11:10 PM Spot on there Keith. Give the hours that I work and the fatigue levels. All I want to do when I get home is sleep and chill out. Everything is progressing, I just need to stay focused and motivated. Should be hitting the dyno again soon. Well when my time lines up with my tuner and with dyno availability. That should give me some mojo.. 1 Link to comment https://www.fordxr6turbo.com/forum/topic/89792-my-build/page/61/#findComment-1687754 Share on other sites More sharing options...
exploitedf6 New Member 16 Member For: 5y 9m 20d Gender: Male Location: Perth, Western Australia Posted 27/08/19 05:04 AM Share Posted 27/08/19 05:04 AM insane write up. will be following this thread & keen to see this finished. I love your carbon work. I wish I had the time, equipment and money todo similar things in that area. what did you machine up on the brembo adaptors? Link to comment https://www.fordxr6turbo.com/forum/topic/89792-my-build/page/61/#findComment-1687770 Share on other sites More sharing options...
espoig Donating Members 249 Member For: 10y 8m 23d Gender: Male Location: Mundaring Posted 27/08/19 06:23 AM Share Posted 27/08/19 06:23 AM Cant wait too see the carbon pieces, been working on a few myself when I have time as well 1 Link to comment https://www.fordxr6turbo.com/forum/topic/89792-my-build/page/61/#findComment-1687771 Share on other sites More sharing options...
HI PSI Member 1,589 Member For: 19y 3d Gender: Male Location: Central Queensland Posted 03/09/19 01:36 PM Author Share Posted 03/09/19 01:36 PM I have a few things on the go at the moment,All at various stages of completion. I'm currently working on a making DJR 320 splitter. It's going to be modified to something similar to what you see on a Audi RS. The bottom vent section will be use to feed ducted air to the front brake rotors. I have also have competed 75% of the mould for the seat backs (Front seats) and I am starting to make infill sections for the chassis, to make the floor flat. On 27/08/2019 at 5:04 AM, exploitedf6 said: insane write up. will be following this thread & keen to see this finished. I love your carbon work. I wish I had the time, equipment and money todo similar things in that area. what did you machine up on the brembo adaptors? Expand Sorry for the late reply. Just finished a rotation of night shift. I milled and modified the standard brackets. We had to mount the caliper 10 mm inboard and extend the caliper height by 5mm, due to the rotor configuration. Essentially, we made new boss's and welded them to the bracket. 😄 Link to comment https://www.fordxr6turbo.com/forum/topic/89792-my-build/page/61/#findComment-1688111 Share on other sites More sharing options...
HI PSI Member 1,589 Member For: 19y 3d Gender: Male Location: Central Queensland Posted 03/09/19 01:55 PM Author Share Posted 03/09/19 01:55 PM Took too long finding a pic that would explain my comment about chassis panels... Here's what I was referring to.. 2 Link to comment https://www.fordxr6turbo.com/forum/topic/89792-my-build/page/61/#findComment-1688113 Share on other sites More sharing options...
HI PSI Member 1,589 Member For: 19y 3d Gender: Male Location: Central Queensland Posted 08/09/19 10:28 AM Author Share Posted 08/09/19 10:28 AM Got a bit done on the seat back mould. Bloody pain in the arse that the plastics are distorted with highs and lows all over the place. Should have a trial piece completed soon... 3 Link to comment https://www.fordxr6turbo.com/forum/topic/89792-my-build/page/61/#findComment-1688233 Share on other sites More sharing options...
HI PSI Member 1,589 Member For: 19y 3d Gender: Male Location: Central Queensland Posted 22/10/19 09:00 PM Author Share Posted 22/10/19 09:00 PM Got some time on the dyno yesterday. Had a few minor issues that held us up a bit, but managed to get most of the 98 ron tune sorted. We pulled up tuning early last night, as we ran out of time and fuel. We managed 733 rwhp (546 kw) @ 24 psi, on 98 ron fuel. We still have more left in it as it was still loving having timing added. It just wants to keep going, with no signs of falling off, even at the 7,800 rpm limiter. Given what we have learnt so far, especially in relation to cam timing, I cannot begin to understand how some of the cars out there are making the power that they are. we used a FG cam map as a baseline, as we were led to believe that they are the best. However, we found that the factory cams tables, effectively choke the crap out of the engine. We've only just started playing in this area and realised an additional 70 hp. We only have a few hours on the dyno today, as both the tuner and I have to leave fore work. So, we're going to put some E85 in it and see what it makes. Fingers crossed for no oil on the floor.... I do have some dyno graph pics and I shall endeavour to get some uploaded tonight. 8 Link to comment https://www.fordxr6turbo.com/forum/topic/89792-my-build/page/61/#findComment-1689362 Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,518 Member For: 17y 1m 18d Gender: Male Location: Melbourne Posted 22/10/19 10:54 PM Share Posted 22/10/19 10:54 PM 546kW on 98 1 Link to comment https://www.fordxr6turbo.com/forum/topic/89792-my-build/page/61/#findComment-1689366 Share on other sites More sharing options...
