Typhoon Member 564 Member For: 20y 6m 23d Gender: Male Posted 07/07/18 03:29 AM Share Posted 07/07/18 03:29 AM Chin up buddy, you’ll sort it. Is there any chance that your fuel pumps/system setup over pressurised the rail. Highly unlikely with -10 setup but Im just curios if this is technically possible with the pumps your running. Are they staged ? Link to comment https://www.fordxr6turbo.com/forum/topic/89792-my-build/page/51/#findComment-1660047 Share on other sites More sharing options...
HI PSI Member 1,586 Member For: 18y 10m 21d Gender: Male Location: Central Queensland Posted 07/07/18 07:50 AM Author Share Posted 07/07/18 07:50 AM Given that the feed and return lines are matching size and has minimal restriction, I cannot envisage an increase of head pressure at the regulator. As it will just bypass at the specified pressure and flow back to the tank. I'm running a KPM 1500hp intank module. At this point in time, both pumps run simultaneously and are not staged. I would like to do so, but the lid section of the module only has one set of terminals and we are therefore stuck with what we have.. I will be rectifying this in the immediate future (When I get the car back), by machining a new top section and installing separate power terminals for each pump, along with a Holley Fuelmat.. Back to the regulator, Fuelab continued with the "damaged from contamination" story line. Personally, I still believe that it was inherit fault with the regulators as they have redesigned the upper section of the regulator and the diaphragm itself. Both parts are in transit and we hope that this resolves the issue permanently.. 6 hours ago, eff xr6t said: Should probably just give up on the car now with this enormous issue arising... it’s a leaking diaphragm not a huge problem to diagnose IMO If you've built a car from scratch with all new component and had to fault find this issue, you would understand the time and frustration associated with such issues. Tell me. how long would it have taken you to identify the issue, given the scenario and your professional experience? I really don't understand your sarcasm, as I was not particularly despondent in my posts about the issue. I was more so disappointed that a high quality and expensive component was DOA. Fuelab replied to my correspondence last night and immediately freighted the required upgraded parts free of charge... 3 Link to comment https://www.fordxr6turbo.com/forum/topic/89792-my-build/page/51/#findComment-1660055 Share on other sites More sharing options...
eff xr6t Member 569 Member For: 11y 6m 16d Posted 07/07/18 08:11 AM Share Posted 07/07/18 08:11 AM Probably take about 15mins to identify the issue. Look at the fuel pressure gauge and see it’s not normal remove the vac line and fuel would start spraying out. Had plenty of bigger issues when building cars then a reg diaphragm popped. 1 Link to comment https://www.fordxr6turbo.com/forum/topic/89792-my-build/page/51/#findComment-1660057 Share on other sites More sharing options...
HI PSI Member 1,586 Member For: 18y 10m 21d Gender: Male Location: Central Queensland Posted 07/07/18 09:22 AM Author Share Posted 07/07/18 09:22 AM Lol !! Sure you would have. Link to comment https://www.fordxr6turbo.com/forum/topic/89792-my-build/page/51/#findComment-1660060 Share on other sites More sharing options...
Typhoon Member 564 Member For: 20y 6m 23d Gender: Male Posted 07/07/18 09:22 AM Share Posted 07/07/18 09:22 AM 5 hours ago, eff xr6t said: Probably take about 15mins to identify the issue. Look at the fuel pressure gauge and see it’s not normal remove the vac line and fuel would start spraying out. Had plenty of bigger issues when building cars then a reg diaphragm popped. Why are you feeling the need to add negativity to the situation? I mean in the bigger picture of this fellas build who are? How are your comments relevant here? Guys had a reg fail, his posting the findings on a public forum and doing a service to other people. You almost sound, jealous! Link to comment https://www.fordxr6turbo.com/forum/topic/89792-my-build/page/51/#findComment-1660085 Share on other sites More sharing options...
Typhoon Member 564 Member For: 20y 6m 23d Gender: Male Posted 07/07/18 10:08 AM Share Posted 07/07/18 10:08 AM Im not sure of the LPH rating of the current pumps in the KPM1500 kit but I know they use to run 2x PN#207 Walbros. These pumps relief valves will kick in at around 80odd psi and start to nose dive pretty quickly. So If they are these pumps I cant imagine they would pressurise the rail, even with both running at the same time. As both pumps would each find the same restriction point and the back pressure would activate the internal relief valve. In more recent times KPM have changed these pumps to a different brand if my memory serves me correctly but I don’t remember which brand they swapped out to, and can’t look at the new pumps flow rates. Even though you may be able to set and hold a base pressure doesn’t mean the diaphragm is capable of constantly holding back persistant pumps and could fail over time. At least that's my understanding of it. FPRs need to be able to hold back the pressure that each pump can deliver in optimal free flowing situations. Over specing fuel lines can have a negative effect on a setup too. Just my opions mate on my learnings and findings. Great project mate well done! 1 Link to comment https://www.fordxr6turbo.com/forum/topic/89792-my-build/page/51/#findComment-1660063 Share on other sites More sharing options...
eff xr6t Member 569 Member For: 11y 6m 16d Posted 07/07/18 10:15 AM Share Posted 07/07/18 10:15 AM Hahahhahaha wtf jealous... riiight Link to comment https://www.fordxr6turbo.com/forum/topic/89792-my-build/page/51/#findComment-1660064 Share on other sites More sharing options...
HI PSI Member 1,586 Member For: 18y 10m 21d Gender: Male Location: Central Queensland Posted 07/07/18 11:20 AM Author Share Posted 07/07/18 11:20 AM If you cannot give constructive feedback, or add value to the thread. Feel free to leave any time.. Link to comment https://www.fordxr6turbo.com/forum/topic/89792-my-build/page/51/#findComment-1660066 Share on other sites More sharing options...
arronm Dropping a turd Gold Donating Members 9,520 Member For: 17y 5m 19d Gender: Male Location: Perth Posted 07/07/18 12:09 PM Share Posted 07/07/18 12:09 PM You can only be mean if you have been a member for over 10 years. Under 5 still on P plates, and we all know what most of them are like. 1 2 Link to comment https://www.fordxr6turbo.com/forum/topic/89792-my-build/page/51/#findComment-1660070 Share on other sites More sharing options...
HI PSI Member 1,586 Member For: 18y 10m 21d Gender: Male Location: Central Queensland Posted 07/07/18 01:34 PM Author Share Posted 07/07/18 01:34 PM (edited) 4 hours ago, HI PSI said: Lol !! Sure you would have... Has a mod been in the thread and modified my post? As my response only comprised of the first line and Typhoons post has somehow morphed into my response. How is this possible??? Edited 07/07/18 01:36 PM by HI PSI Link to comment https://www.fordxr6turbo.com/forum/topic/89792-my-build/page/51/#findComment-1660076 Share on other sites More sharing options...
