  • 3 weeks later...
  • Member For: 19y 6d
I actually got some work done on the car today....
Dump is back on. So is the intake. Egt's are fitted, just need connection.... Hopefully the new ICC screen will be installed tomorrow. Might try for some bigger brakes and fit the new wheels...
The new screen...
Edited by HI PSI
  • Like 3
  • 2 weeks later...
Fitted the new 360mm offset rotors. They look huge.
I they ended up sitting 10.4 mm further inboard. As you can see there is now ample room to fit the caliper, even with 19" Vertini Drifts.  The caliper brackets are currently being modified to suit.  Should be finished by Friday.
  • Like 4
  • 2 weeks later...
I fitted the S1 Sequential shifter yesterday. We ran in to a teething problem, with the tumbler barrel being different for the Magnum.  Simon is shipping the required components tomorrow. So, I hope to sort the problem when I return home on Monday..
After which,  we'll be spending some time on getting the cold start sorted.  Caliper brackets will be finished next week also. Getting closer to practical completion....
  • Like 2
  On 02/10/2017 at 4:48 AM, arronm said:
Interested in the shifter.  Can you post some details.
Expand
What would you like to know,  Arron?
