HI PSI Member 1,589 Member For: 18y 11m 26d Gender: Male Location: Central Queensland Posted 14/02/17 11:51 AM Author Share Posted 14/02/17 11:51 AM What parts do you need? Link to comment https://www.fordxr6turbo.com/forum/topic/89792-my-build/page/41/#findComment-1631672 Share on other sites More sharing options...
masda74 To Loud Gold Donating Members 4,112 Member For: 13y 5m 21d Gender: Male Location: WA, Perth Posted 14/02/17 12:06 PM Share Posted 14/02/17 12:06 PM EVERYTHING!!!!! 2 Link to comment https://www.fordxr6turbo.com/forum/topic/89792-my-build/page/41/#findComment-1631673 Share on other sites More sharing options...
tazzanz Donating Members 573 Member For: 9y 9m 19d Gender: Male Location: NZ Posted 14/02/17 03:37 PM Share Posted 14/02/17 03:37 PM On 14/02/2017 at 11:51 AM, HI PSI said: What parts do you need? Expand T56 YO! Do you have a complete conversion to go along with it? Link to comment https://www.fordxr6turbo.com/forum/topic/89792-my-build/page/41/#findComment-1631679 Share on other sites More sharing options...
HI PSI Member 1,589 Member For: 18y 11m 26d Gender: Male Location: Central Queensland Posted 14/02/17 08:28 PM Author Share Posted 14/02/17 08:28 PM Pretty much. I have everything except the shifter surround and boot. T56 box with shifter and crossmember , Alloy csc, Tenflon line and bleed. Fpv pedal box, including resevoir, Tailshaft and diff yolk. I have a Mal Wood option 3 and 5 clutch. Choice is yours.. Chasing $2500 Option 3 clutch has been freshly surfaced and has new clutch plate. Option 5 clutch has done around 500km and will be $500 more than option 3. Can palletise and arrange forklift for freight collection. You arrange freight... 1 Link to comment https://www.fordxr6turbo.com/forum/topic/89792-my-build/page/41/#findComment-1631685 Share on other sites More sharing options...
JETURBO ...JD TUNING ADELAIDE... Gold Donating Members 23,708 Member For: 16y 11m 20d Gender: Male Location: Adelaide Posted 14/02/17 08:31 PM Share Posted 14/02/17 08:31 PM That's a good deal there ! Link to comment https://www.fordxr6turbo.com/forum/topic/89792-my-build/page/41/#findComment-1631687 Share on other sites More sharing options...
sixman Donating Members 601 Member For: 20y 9m 29d Gender: Male Location: Hills District, NSW Posted 14/02/17 09:12 PM Share Posted 14/02/17 09:12 PM Yes its a great deal! Link to comment https://www.fordxr6turbo.com/forum/topic/89792-my-build/page/41/#findComment-1631688 Share on other sites More sharing options...
tazzanz Donating Members 573 Member For: 9y 9m 19d Gender: Male Location: NZ Posted 15/02/17 01:39 AM Share Posted 15/02/17 01:39 AM On 14/02/2017 at 8:28 PM, HI PSI said: Pretty much. I have everything except the shifter surround and boot. T56 box with shifter and crossmember , Alloy csc, Tenflon line and bleed. Fpv pedal box, including resevoir, Tailshaft and diff yolk. I have a Mal Wood option 3 and 5 clutch. Choice is yours.. Chasing $2500 Option 3 clutch has been freshly surfaced and has new clutch plate. Option 5 clutch has done around 500km and will be $500 more than option 3. Can palletise and arrange forklift for freight collection. You arrange freight...Pm you Link to comment https://www.fordxr6turbo.com/forum/topic/89792-my-build/page/41/#findComment-1631707 Share on other sites More sharing options...
ROB83R Member 1,632 Member For: 9y 2d Gender: Not Telling Location: Radioactive wasteland Posted 21/02/17 04:00 AM Share Posted 21/02/17 04:00 AM That's much better than the one I put you onto. I'd snap that up myself if I had the cash. 1 Link to comment https://www.fordxr6turbo.com/forum/topic/89792-my-build/page/41/#findComment-1632421 Share on other sites More sharing options...
HI PSI Member 1,589 Member For: 18y 11m 26d Gender: Male Location: Central Queensland Posted 20/04/17 01:31 PM Author Share Posted 20/04/17 01:31 PM Well, it has come to a point where I am happy to work on the car again. Let's hope that it lasts.. LOL With the assistance of some forum members, I have identified a configuration issue with the heater hoses. I think that it is causing the passengers side air con to be warm, so this will be rectified asap. As it will be far easier while the turbo and exhaust manifold is off. Speaking of which, here is a pic of the exhaust manifold with the new EGT bungs. I sent it and the two rear housings away for ceramic coating before Christmas. As an afterthought, we have installed another bung on the wastgate pipe, prior to the gate. We have done this, with the intention of monitoring back pressure during tuning. This will assist us to identify the limits of the exhaust sizes housing that I have. I will likely get a tune done to match each, so that I can change the output and characteristics of the setup. I just wish that I had installed it prior to sending it to be coated... It has been welded internally, so damage to the ceramics is negligible. I must admit, that it is far more attractive than it previously was... I have also decided that the car will be heading Harvey Bay for its tune, as it is the closest hub dyno available. More updates soon.. 1 Link to comment https://www.fordxr6turbo.com/forum/topic/89792-my-build/page/41/#findComment-1637002 Share on other sites More sharing options...
HI PSI Member 1,589 Member For: 18y 11m 26d Gender: Male Location: Central Queensland Posted 28/04/17 05:51 AM Author Share Posted 28/04/17 05:51 AM (edited) Well, it took me around and hour to get the manifold back on and the wastegate connected. The turbo should be back on tomorrow, when I get the new bolts. In other news, I have ordered a set of 365 mm rotors and hats. So the brembo's will be fitted soon.. I will have to make some spacers for the mounting brackets, as these rotors sit around 15 mm further inboard than the traditional brembo items. There appears to be a two week delay on the hats, so I will post some pics when they arrive. Edited 28/04/17 05:52 AM by HI PSI 2 Link to comment https://www.fordxr6turbo.com/forum/topic/89792-my-build/page/41/#findComment-1637626 Share on other sites More sharing options...
