Peppy_t92 Silver Donating Members 748 Member For: 12y 1m 2d Gender: Male Location: Liverpool Posted 16/12/14 09:13 AM Share Posted 16/12/14 09:13 AM Exactly what ratter said... The desired boost table is RPM vs Intake Valve Temp Link to comment https://www.fordxr6turbo.com/forum/topic/89746-hotcold-boost-pressure-difference/page/2/#findComment-1517878 Share on other sites More sharing options...
Vrdesign Member 42 Member For: 11y 4m 6d Posted 16/12/14 09:33 AM Author Share Posted 16/12/14 09:33 AM Thanks for the reply, what sort of compensation would you guys generally work with? Does a 3 psi swing over a 15 deg temp change sound normal?17 psi @ 15 deg, 14 psi @ 30 deg Link to comment https://www.fordxr6turbo.com/forum/topic/89746-hotcold-boost-pressure-difference/page/2/#findComment-1517882 Share on other sites More sharing options...
Peppy_t92 Silver Donating Members 748 Member For: 12y 1m 2d Gender: Male Location: Liverpool Posted 16/12/14 11:19 AM Share Posted 16/12/14 11:19 AM I would be very interested to see Ratters answer to that one mate.. When I set them I generally leave it the same when cold and at running temperature, then taper it down at the higher temperatures... What you have to remember is your IAT will be higher then ambient temp with a lot of different factors playing a part, like boost level, intercooler efficiency, airbox etc.. for a 30* ambient day your intake temps will be up in the 40*-50+* where as on a cool night with 15* ambient temps IAT could be as low as 20-30*.... Also timing maps change with IAT and ECT, this could effect boost aswell... I like closed loop, but I have seen a lot of reputable shops using open loop Link to comment https://www.fordxr6turbo.com/forum/topic/89746-hotcold-boost-pressure-difference/page/2/#findComment-1517907 Share on other sites More sharing options...
ratter Member 6,793 Member For: 18y 11m 8d Gender: Male Location: @ my laptop Posted 16/12/14 11:27 AM Share Posted 16/12/14 11:27 AM if tuned in closed loop, you can adjust boost to what ever number mechanically possible at any rpm and any IAT temp setting, why you would I have no idea, but yes you can control different boost at different temps, but if tuned in open loop the boost will change according to gear used, IAT, turbo housing temp, timing changes etc 1 Link to comment https://www.fordxr6turbo.com/forum/topic/89746-hotcold-boost-pressure-difference/page/2/#findComment-1517908 Share on other sites More sharing options...
IH8TOADS Silver Donating Members 3,618 Member For: 19y 9m 27d Gender: Male Location: OZ Posted 16/12/14 01:26 PM Share Posted 16/12/14 01:26 PM Yeah it's completely normal as a lot (not all) will use the same open loop wastegate duty cycle for all IAT. Ideally you would pull a bit of duty cycle for the colder temps to maintain a consistent boost pressure....if when you force open loop.Some just run an external / aftermarket boost controller and have a cold temp boost curve that you can enter at the touch of a button. Link to comment https://www.fordxr6turbo.com/forum/topic/89746-hotcold-boost-pressure-difference/page/2/#findComment-1517916 Share on other sites More sharing options...
