  • Member For: 12y 9m 20d
All cars are different, dynos are different also.
When I did mine, I did all the best stuff I could to give it the best chance possible.
Here is mine.
http://www.fordxr6turbo.com/forum/topic/89309-autotech-tuned-fg/
Agree with Plug on port/flapper/actuator.
I didn't do mine and it's fine. You could of put that towards a quality cooler.
Edited by Seaton
  • New Member
  • Member For: 10y 7m 28d
Unfortunatly the green line is after a custom tune so yeah took it hard without lube on the first attempt,
second tune was by a reputable tuner in Melbourne and he suggests that injectors are not sufficiant enough to control Air/Fuel ratios
he said to install som ID1000? Would this help?
  • Dropping a turd
  • Member For: 17y 7m 20d
You got a 40 kW gain.
That said. It's laying over before 5000. So at over 16psi I would say it needs valve springs.
750cc injectors will be fine for that power
Edited by arronm
  • ...JD TUNING ADELAIDE...
  • Member For: 17y 16d
Its not a valve spring issue arron
Small turbo CAN NOT. Maintain nore than ~11psi at theend if its 16 in early so its just the hard taper off from the hard in early
The lower target boost the more linear the graph looks the higher target boost the more "bell" curve
Depending on what the customer wants each has its pros n cons
  • New Member
I noticed on your earlier post that you made 290.9 on 13PSI, so excuse me for being a little dumb but if you put in more boost eg. 16.5PSI sould my figure not be higher than the car you tuned at 13PSI?
  • MattyP
  • Cruise Control
  • Member For: 13y 1m 12d
Intercooler and tuner holding you back mate
And I had a totally standard turbo and went 350 on e85 (310 on 98)
Who was the tuner
  • Dropping a turd
No because you need supporting mods for that. Large intake, cooler and exhaust.
Our F6 made 317 on 10psi. With Large intake, cooler and exhaust.
No boost is not always a direct relation to power
More boost = more heat = less timing
Timing power always beats boost power and considering your running a stock f6 cooler this should of stood out to the tuner when selecting your desired boost target honestly so like we did went for less boost and more repeatability ;)
  • Like 2
