2011 G6Et Mods, Guess What Rwkw This Made!
WEPN6T
  • Too heavy needs boost
  • Member For: 11y 6m 6d
no e85 yet I want to do a run first and then see if its worth going it. im a broke man now so I cant afford things going wrong all the time. building the car fund back up. Hopefully have another 5-10k to play with at the end of next year.
  • Dropping a turd
  • Member For: 17y 3m 16d
Well a few days u stated your car made 400 no 396kw..
so to quote ANY figure your car makes is really no benefit to this thread.. Given BA XR manual, cams etc DOES NOT EQUAL G6ET stockish with ZF.. !!!
AND your first post in this thread guessing this blokes power is only 283kw SO im assuming your saying if he puts a sh*t old f6 3582 on he will somehow make 350kw so 67kw increase by a small turbo upgrade ??
I dont understand any of this. Lay off the drugs dude. Just say NO.....
Edited by arronm
  • Like 2
  • Carnage on the Garage Floor
  • Member For: 14y 9m 1d
Final trim 358 at 17psi. Nudged 370 on a couple of runs. I'm running the Herrod E85 spec drop in but yours being a ute is harder to fit from what I understand (access issues) so perhaps that's why they recommended the surge etc. That is a better set up but $$$ come into it. The Herrod drop in is about $550 from memory vs $1100 odd for the p/w single pump. And yes, they were very impressed with the little GTX :)
  • MattyP
  • Cruise Control
  • Member For: 12y 9m 8d
One thing to remember is drive ability
Peak kw is great for pissing contests but drive ability is what you want for a streeter
  • in the mid....not the bum like some
  • Member For: 11y 9m 20d
Measured the stock cradle and a larger cradle capacity today and the stock cradle holds 300ml of fuel and the larger ones hold 450ml....definitely not a setup fit for drags/extended WOT runs.
Thought it might be interesting for a few of you to know as seems quite a few run this setup and think the larger cradle is actually a fix for surge(sellers state this in adds so its not unreasonable to think so).
Also if running E85 on the KPM in-tank the brass fittings need to be changed out for a true e85 setup.
  • MattyP
  • Cruise Control
It's not all about cradle capacity
Remember if the cradle is fully submerged and say using under 400lph a walbro 460 will run all day long
  • Member For: 18y 8m 16d
The swirl pot is being filled continuously from fuel forced into it when a correct rated pump is used for the application, even when fuel levels are below the top the swirl pot
  • Like 2
