GeGe6 Donating Members 1,980 Member For: 12y 11m 12d Gender: Male Location: Perth, SOR Posted 07/04/15 12:47 AM Share Posted 07/04/15 12:47 AM Masda, I thought you where going Project Mu pads notultimates? Link to comment https://www.fordxr6turbo.com/forum/topic/89687-brake-shudder-on-the-hunt-for-the-problem-over-heated-brake-fluid/page/14/#findComment-1538638 Share on other sites More sharing options...
PTR_NITRO_FG Donating Members 3,214 Member For: 12y 25d Gender: Male Location: NOR Perth Posted 07/04/15 01:08 AM Share Posted 07/04/15 01:08 AM On 07/04/2015 at 12:08 AM, masda74 said: FormulaFg, could you please explain why you would not get slotted rotors?And also what pads you have been using that has caused your t3's to warp? Link to comment https://www.fordxr6turbo.com/forum/topic/89687-brake-shudder-on-the-hunt-for-the-problem-over-heated-brake-fluid/page/14/#findComment-1538643 Share on other sites More sharing options...
masda74 To Loud Gold Donating Members 4,112 Member For: 13y 6m 20d Gender: Male Location: WA, Perth Posted 07/04/15 01:22 AM Author Share Posted 07/04/15 01:22 AM On 07/04/2015 at 12:47 AM, GeGe6 said: Masda, I thought you where going Project Mu pads notultimates?I decided at the last minute to get the ultimates installed instead of the Project MU pads.I thought to myself that if I liked the Project MU pads, that I would most probably never put the Ultimates in.At the same time, If the rotors were not skimmed right and there was still a bit of crap on there, the Ultimates would clean the up.I was expecting more BITE from the ultimates to be honest. They do bite, but not as hard as the focus OEM brake pads.I also have to press the brake pedal less for the car to stop now. I am sure that the Ultimates will be used up by the 100000km mark and hen the project MOOOOOOO go in. Link to comment https://www.fordxr6turbo.com/forum/topic/89687-brake-shudder-on-the-hunt-for-the-problem-over-heated-brake-fluid/page/14/#findComment-1538646 Share on other sites More sharing options...
GeGe6 Donating Members 1,980 Member For: 12y 11m 12d Gender: Male Location: Perth, SOR Posted 07/04/15 01:24 AM Share Posted 07/04/15 01:24 AM You have braided lines, right? Link to comment https://www.fordxr6turbo.com/forum/topic/89687-brake-shudder-on-the-hunt-for-the-problem-over-heated-brake-fluid/page/14/#findComment-1538647 Share on other sites More sharing options...
FormulaFG Donating Members 68 Member For: 11y 1d Posted 07/04/15 01:27 AM Share Posted 07/04/15 01:27 AM On 07/04/2015 at 12:08 AM, masda74 said: FormulaFg, could you please explain why you would not get slotted rotors?Plain rotors create less dust than slotted/cross drilled ones. The slots on the face cut onto the pad which in my opinion helps contribute to the shuddering. That's why I think the ultimates work well with the T3s. They are just as aggressive towards the rotor as the rotor is towards them. On 07/04/2015 at 1:08 AM, PTR_NITRO_FG said: And also what pads you have been using that has caused your t3's to warp? I don't have warped discs, I have resin deposits. Bremtec Endures I have been using. From my research, and I've done a lot, you can't use ceramic/low dust pads on the slotted rotors. Link to comment https://www.fordxr6turbo.com/forum/topic/89687-brake-shudder-on-the-hunt-for-the-problem-over-heated-brake-fluid/page/14/#findComment-1538649 Share on other sites More sharing options...
masda74 To Loud Gold Donating Members 4,112 Member For: 13y 6m 20d Gender: Male Location: WA, Perth Posted 07/04/15 01:48 AM Author Share Posted 07/04/15 01:48 AM On 07/04/2015 at 1:24 AM, GeGe6 said: You have braided lines, right?Yes I do have Braided lines, which I got from RBS.However with the OEM rotors and pads in, it felt like it travelled a bit more to get the car to stop.With the DBA T3s and the ultimates in, the brake pedal does not travel as much. I just don't know how to explain it.The car just stops with less effort?? Link to comment https://www.fordxr6turbo.com/forum/topic/89687-brake-shudder-on-the-hunt-for-the-problem-over-heated-brake-fluid/page/14/#findComment-1538652 Share on other sites More sharing options...
PTR_NITRO_FG Donating Members 3,214 Member For: 12y 25d Gender: Male Location: NOR Perth Posted 07/04/15 01:49 AM Share Posted 07/04/15 01:49 AM On 07/04/2015 at 1:22 AM, masda74 said: I am sure that the Ultimates will be used up by the 100000km mark and hen the project MOOOOOOO go in.One too many zero's I think! 100k from pads seems optimistic still rekon they should last more than 10k though On 07/04/2015 at 1:27 AM, FormulaFG said: I don't have warped discs, I have resin deposits. Bremtec Endures I have been using. From my research, and I've done a lot, you can't use ceramic/low dust pads on the slotted rotors.Yep ensdures for me too unfortunately....still probably lean towards PMU NS400; only cause a certain someone loves them. Link to comment https://www.fordxr6turbo.com/forum/topic/89687-brake-shudder-on-the-hunt-for-the-problem-over-heated-brake-fluid/page/14/#findComment-1538653 Share on other sites More sharing options...
masda74 To Loud Gold Donating Members 4,112 Member For: 13y 6m 20d Gender: Male Location: WA, Perth Posted 07/04/15 02:19 AM Author Share Posted 07/04/15 02:19 AM 1 to many zeros?? I think not.I am at 56k already. so about 44000 km to reach the magic 100,000km. Link to comment https://www.fordxr6turbo.com/forum/topic/89687-brake-shudder-on-the-hunt-for-the-problem-over-heated-brake-fluid/page/14/#findComment-1538658 Share on other sites More sharing options...
masda74 To Loud Gold Donating Members 4,112 Member For: 13y 6m 20d Gender: Male Location: WA, Perth Posted 10/03/17 03:46 AM Author Share Posted 10/03/17 03:46 AM I thought I would update this thread to keep it up to date. It has been a while and I forgot about it. I found it in my searches for posts I may have started. So It is 2017 and I still have the Bendix ultimates and the dba 4000...... The shudder has not shown itself since. The car still stops in an orderly fashion from higher speeds. These pads are however driving me bonkers with the amount of dust I get on my rims. At one stage, I had someone ask me why I had the luxury 19" rims at the rears and the XR50 dark grey rims at the front. That was an embarrassing and awkward moment for me. Anyways I just hit 88888KM last week so not far till I hit 100,000km. 2 Link to comment https://www.fordxr6turbo.com/forum/topic/89687-brake-shudder-on-the-hunt-for-the-problem-over-heated-brake-fluid/page/14/#findComment-1633981 Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,561 Member For: 17y 2m 9d Gender: Male Location: Melbourne Posted 10/03/17 03:48 AM Share Posted 10/03/17 03:48 AM haha good quality pads and dust is such a pain, but a small hassle compared to brake shudder (etc)... that reminds me, I should wash my car and polish it again. 88k km, hardly even broken in Link to comment https://www.fordxr6turbo.com/forum/topic/89687-brake-shudder-on-the-hunt-for-the-problem-over-heated-brake-fluid/page/14/#findComment-1633983 Share on other sites More sharing options...
