masda74 To Loud Gold Donating Members 4,112 Member For: 13y 3m 8d Gender: Male Location: WA, Perth Posted 18/02/15 12:54 AM Author Share Posted 18/02/15 12:54 AM What is there to say. They were used by PhilMeUp in his build thread and caught my attention.Ever wanted to change your brake fluid, but needed two people to do the job.Hate having to depend on someone else to help get the job done?Well speed bleeders is the answer. Allows you to do the job on your own.http://www.speedbleeder.com/This is the page with the sizes listedhttp://www.speedbleeder.com/size.htmThe part recommended by PhilMeUp was the sb1010s. This was searched for high and dry on Aussie soil without any success.I finally caved in and ordered through Ebay. I did look at amazon as recommended by PhilMeIUp but I have not purchased from there.I feel more comfortable with Ebay and so I got this ordered from this seller due to his ratings.http://www.ebay.com.au/itm/331360902859?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT Link to comment Share on other sites More sharing options...
GeGe6 Donating Members 1,978 Member For: 12y 8m 3d Gender: Male Location: Perth, SOR Posted 18/02/15 12:55 AM Share Posted 18/02/15 12:55 AM More so after link for purchase, size thread etc.Thank you Link to comment Share on other sites More sharing options...
masda74 To Loud Gold Donating Members 4,112 Member For: 13y 3m 8d Gender: Male Location: WA, Perth Posted 18/02/15 03:36 AM Author Share Posted 18/02/15 03:36 AM You upgraded your callipers at one stage or another did you not Mick?I am not sure if your callipers will be different to mine. may want to measure your current nipple to order the right size??????? Link to comment Share on other sites More sharing options...
GeGe6 Donating Members 1,978 Member For: 12y 8m 3d Gender: Male Location: Perth, SOR Posted 18/02/15 03:37 AM Share Posted 18/02/15 03:37 AM Spot on Link to comment Share on other sites More sharing options...
PhilMeUp Member 1,045 Member For: 16y 7m 22d Gender: Male Location: Perth, Western Australia Posted 18/02/15 05:30 AM Share Posted 18/02/15 05:30 AM More details on speed bleeders.More info: http://www.fordxr6turbo.com/forum/topic/75252-brake-nipples-speed-bleeders-and-brembo-falcon-standard-brakesThey allow you to flush/bleed brakes on your own. Loosen the nipple, go pump the brake pedal and then tighten the nipple again.I flush the brake fluid on my taxi every 4 to 6 months. I do this late at night on my own. Last time it took me 45 minutes to completely flush the fluid and adjust the handbrake. Link to comment Share on other sites More sharing options...
GeGe6 Donating Members 1,978 Member For: 12y 8m 3d Gender: Male Location: Perth, SOR Posted 18/02/15 05:34 AM Share Posted 18/02/15 05:34 AM Phil, just a quick one.Would you know the size thread etc for BA/BF upgrade fronts (325mm PBR)?Rears are territory 328mm. Link to comment Share on other sites More sharing options...
PhilMeUp Member 1,045 Member For: 16y 7m 22d Gender: Male Location: Perth, Western Australia Posted 18/02/15 05:49 AM Share Posted 18/02/15 05:49 AM You upgraded your callipers at one stage or another did you not Mick?I am not sure if your callipers will be different to mine. may want to measure your current nipple to order the right size???????The only Falcon caliper that I've come across so far that doesn't use an SB1010S (ie the same as a 639630) is the PBR 328mm rear caliper. That one uses the longer SB1010.The SB1010S works in:- The standard Falcon front calipers (both 298 and 322mm).- The PBR 325mm calipers.- Brembo 4 and 6 piston calipers - front and rear.They are all a 10 x 1.0 thread. It's just that the hole is deeper on the 328mm caliper, so that requires a longer threaded section on the nipple.All these things do is allow you to bleed or flush the brake fluid on your own. If you've got a friend or woman around that can help then he/she can pump the brake pedal while you loosen and tighten the standard nipple. I'm always doing stuff late at night on my own, so for me they are essential. One of these days I'll sort out a pressure bleeder bottle that pushes brake fluid through at the reservoir.I've been using the same set on my taxi for a few years now. There's goo on the thread to maintain a seal when I loosen the nipples. Although I bought a bottle of replacement goo a few years ago, I haven't had to use it yet. The goo on the original speed bleeders is still working. Link to comment Share on other sites More sharing options...
masda74 To Loud Gold Donating Members 4,112 Member For: 13y 3m 8d Gender: Male Location: WA, Perth Posted 20/02/15 03:30 AM Author Share Posted 20/02/15 03:30 AM Control arm bushes are shagged. Not sure how peddlers checked this all as part of their check.Getting them replaced with nolothane gear. Also getting a camber kit put in as part of the deal.Will have to wait till later on to find out if it helps reduce the issue. Link to comment Share on other sites More sharing options...
GeGe6 Donating Members 1,978 Member For: 12y 8m 3d Gender: Male Location: Perth, SOR Posted 20/02/15 03:31 AM Share Posted 20/02/15 03:31 AM When you doing it? Link to comment Share on other sites More sharing options...
masda74 To Loud Gold Donating Members 4,112 Member For: 13y 3m 8d Gender: Male Location: WA, Perth Posted 20/02/15 04:30 AM Author Share Posted 20/02/15 04:30 AM it's being done since this morning. I pickup the car this afternoon after work.Why you ask? Link to comment Share on other sites More sharing options...
