barnz Member 3,047 Member For: 11y 6m 27d Gender: Male Location: Brisbane Posted 16/12/14 07:25 AM Share Posted 16/12/14 07:25 AM On 16/12/2014 at 1:30 AM, PTR_NITRO_FG said: yeah no sh*t hey....since ralph & butt plug say the pads are garbage....I'm thinking when I change to the DBA rotors, I'll use a different set of pads.since everyone raves on about the A1RM's.....might give them a try (hopefully the brake dust doesn't drive me crazy)....but since its a while off; I might wait and see how Luke finds those project mu pads I'm hoping these Pedders guys can spot the bushes that are causing me grief....if not I will still try the radius arm to chassis bushes & upper inner control arm bushes as suggested by Pat & Luke. f*ck I hate shudder!!!! I personally like the a1rm's and I'm running them atm, not going to be your cup of tea if you dont like dust and noise but holy fark they work. 1 Link to comment https://www.fordxr6turbo.com/forum/topic/89687-brake-shudder-on-the-hunt-for-the-problem-over-heated-brake-fluid/page/6/#findComment-1517862 Share on other sites More sharing options...
aiboart Member 665 Member For: 20y 5m 1d Posted 16/12/14 09:17 AM Share Posted 16/12/14 09:17 AM On 16/12/2014 at 6:49 AM, Ralph Wiggum said: If the current pads have overcooked and dumped resin on the rotors they are cactus and hard stops won't fix it.Depends.Had it once on two piece discs. After much running around trying to get a solution, a simple brisk drive and long cool down resolved the issue. Link to comment https://www.fordxr6turbo.com/forum/topic/89687-brake-shudder-on-the-hunt-for-the-problem-over-heated-brake-fluid/page/6/#findComment-1517879 Share on other sites More sharing options...
discostig Manual mode ________________________ All day, erryday Donating Members 13,798 Member For: 17y 6m 23d Gender: Male Location: Probably above atmospheric pressure Posted 16/12/14 09:28 AM Share Posted 16/12/14 09:28 AM Not really gonna help but I can heartily recommend a good hard drive through the back roads on the way to Pemberton.Cured my brake squeal (T3s with Remsa pads) and I think burned off some of the oil in my intercooler or intake manifold or something as the car seems to have more snappy off the line performance hahaha. Feels like it revs faster after the caning I handed out.Curing brake squeal I'm happy about though. Guess it was the medium to hard braking but never stopping for 10-15 minutes at a time.Fingers crossed for you it's simply a resin issue as said. Different pads might remove it as they use different compounds?Remember in the QFM pads range the HPX are the mild street version and A1RM are harder on rotors and more track oriented (have only used HPX myself). Link to comment https://www.fordxr6turbo.com/forum/topic/89687-brake-shudder-on-the-hunt-for-the-problem-over-heated-brake-fluid/page/6/#findComment-1517880 Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,332 Member For: 19y 8m 24d Gender: Male Location: Perth Posted 16/12/14 11:12 AM Share Posted 16/12/14 11:12 AM On 16/12/2014 at 9:17 AM, aiboart said: Depends.Had it once on two piece discs. After much running around trying to get a solution, a simple brisk drive and long cool down resolved the issue.where you running these pads tho?http://bremtec.com.au/product-range/brake-pads/endure/ Link to comment https://www.fordxr6turbo.com/forum/topic/89687-brake-shudder-on-the-hunt-for-the-problem-over-heated-brake-fluid/page/6/#findComment-1517905 Share on other sites More sharing options...
barnz Member 3,047 Member For: 11y 6m 27d Gender: Male Location: Brisbane Posted 16/12/14 10:36 PM Share Posted 16/12/14 10:36 PM Imo the a1rm's aren't an ideal street pad, its more like a track pad that still has a decent coefficient from cold. Just a warning coz they are very good and the rave reviews are correct but honestly some guys will struggle to live with them day to day. I have found them quite noisy at times and the dust is brutal. I personally dont give a sh*t about either of those things though. Would love to try the t3 a1rm combo in some brembos, would be unreal. There are of course better pads around but not for 120 bucks Link to comment https://www.fordxr6turbo.com/forum/topic/89687-brake-shudder-on-the-hunt-for-the-problem-over-heated-brake-fluid/page/6/#findComment-1517957 Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,332 Member For: 19y 8m 24d Gender: Male Location: Perth Posted 16/12/14 11:15 PM Share Posted 16/12/14 11:15 PM I didn't rate them personally. I preferred Remsa's. I really hoping the pmu ns400's stop like Remsa's without the dust. Link to comment https://www.fordxr6turbo.com/forum/topic/89687-brake-shudder-on-the-hunt-for-the-problem-over-heated-brake-fluid/page/6/#findComment-1517964 Share on other sites More sharing options...
discostig Manual mode ________________________ All day, erryday Donating Members 13,798 Member For: 17y 6m 23d Gender: Male Location: Probably above atmospheric pressure Posted 16/12/14 11:45 PM Share Posted 16/12/14 11:45 PM How much more $ are they than Remsa pads? Link to comment https://www.fordxr6turbo.com/forum/topic/89687-brake-shudder-on-the-hunt-for-the-problem-over-heated-brake-fluid/page/6/#findComment-1517968 Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,332 Member For: 19y 8m 24d Gender: Male Location: Perth Posted 17/12/14 12:21 AM Share Posted 17/12/14 12:21 AM They where $286 delv'd so I spose around $40 more? Link to comment https://www.fordxr6turbo.com/forum/topic/89687-brake-shudder-on-the-hunt-for-the-problem-over-heated-brake-fluid/page/6/#findComment-1517974 Share on other sites More sharing options...
masda74 To Loud Gold Donating Members 4,112 Member For: 13y 6m 17d Gender: Male Location: WA, Perth Posted 17/12/14 12:45 AM Author Share Posted 17/12/14 12:45 AM Double post? must be on tapatalk If I were to fork out $286 for them to be delivered to my door step, they better be made of gold.Just out of curiosity, if I were to get them, how long on average would they last? 50,000km / 60,000km? Link to comment https://www.fordxr6turbo.com/forum/topic/89687-brake-shudder-on-the-hunt-for-the-problem-over-heated-brake-fluid/page/6/#findComment-1517978 Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,332 Member For: 19y 8m 24d Gender: Male Location: Perth Posted 17/12/14 12:48 AM Share Posted 17/12/14 12:48 AM If you think $286 for a set of performance front and rear pads to suit Brembo calipers is expensive I'd suggest you find a new hobby. 1 Link to comment https://www.fordxr6turbo.com/forum/topic/89687-brake-shudder-on-the-hunt-for-the-problem-over-heated-brake-fluid/page/6/#findComment-1517979 Share on other sites More sharing options...
