Gearbox/tailshaft Knock At <10Kms With > 30% Throttle.
rollex
  • Member For: 10y 9m 2d
I specifically asked them to change it but both places said it looks fine and has no play so why change it ?
Edited by rollex
  • Replies 29
  • Created
  • Last Reply
Top Posters In This Topic
What makes you so sure it is the centre bearing? If I replace it and it isn't the cause what do I do then... start replacing more bits until I've replaced everything?
Edited by rollex
  • I'm getten too old for this s**t
  • Bronze Donating Members
  • Member For: 11y 11m 3d
Was gunna (hehe - gunna) respond with - either take the advice or don't take it....the choice is yours - but thought about it and decided not too
Well I have conflicting advice, two guys who have looked at it and said it is fine, and two guys on the internet who say replace it.
I'm curious why you say replace it, have you seen centre bearings with no play that look fine but still clunk? I'm no expert so I have no idea.
  • Member For: 16y 7m 22d
Did this with my FPV ute. Climbed under and tried to move the tail shaft around. Wouldn't budge, so I assumed that the bearing was fine.
At inspection time, there was a slight tear in the rubber on top of the bearing surround.
Bought a new centre bearing from Hardy Spicer and fitted it easily enough.
It eliminates one possibility, and means that there's one less thing to go wrong in the future.
  • less WHY; more WOT
  • Site Developer
  • Member For: 16y 11m
Do a dyno run while looking under the car; you'll see the CB shift around. If it doesn't move on a dyno then you'll have to look elsewhere.
  • Member For: 14y 2m 1d
Just had my CB replaced today, signs were vibration under load mainly up hill on the highway, and excessive shaft play.
See how it's off centre and the cracking up top of the rubber where it's stretched.
Place I did it also found that when I had my broken diff bolt and hat replaced last year by ford that whoever did it had no idea what they were doing, the handbrake cable was jammed in against the diff and rubbing through, explains why my diff was so clunky before as well, feels nice and tight in the rear now it's great! Didn't get charged for that fix up either,!
Love the table cloth
Very 1970's spec
