rollex Member 683 Member For: 10y 5m 22d Gender: Male Location: Australia Posted 30/11/14 04:07 AM Author Share Posted 30/11/14 04:07 AM (edited) I do know my engine mounts are pretty average as the whole car rocks when I rev the engine and the bonnet shakes when I start it, however this all happened before the knocking noise. Is having shagged engine mounts likely to cause any issues other than increased NVH?I'll get the centre bearing done with the diff bushes next week, if it is something else I'll get them to do that as well. Car has 190,000 on it so not surprised, pretty much every other bush and bearing has been replaced on it already. Edited 30/11/14 04:09 AM by rollex Link to comment Share on other sites More sharing options...
Rintaro New Member 22 Member For: 12y 8m 20d Gender: Male Posted 30/11/14 10:10 AM Share Posted 30/11/14 10:10 AM A bf egas wagon I had for a while broke 3 radiator hoses because of a shagged mounts... or so ford told me Link to comment Share on other sites More sharing options...
polishboi.luke Member 89 Member For: 10y 9d Gender: Male Location: Perth w.a Posted 04/12/14 03:13 AM Share Posted 04/12/14 03:13 AM tailshaft center bearing is cactus. there around 50-80 dollars to buy. replace your UJ while your there there no more then 20 dollars for a new kit. drives like a new car when you replace it Link to comment Share on other sites More sharing options...
rollex Member 683 Member For: 10y 5m 22d Gender: Male Location: Australia Posted 04/12/14 03:28 AM Author Share Posted 04/12/14 03:28 AM (edited) Went to get it and the diff bushes replaced, they said the centre bearing was fine and the diff bush was completely f*cked and that was the cause. Drive the car home and find it still makes the noise just not as bad. The rear end is definitely better now but annoyed I have to take it back again.FFS Edited 04/12/14 03:28 AM by rollex Link to comment Share on other sites More sharing options...
JETURBO ...JD TUNING ADELAIDE... Gold Donating Members 23,708 Member For: 16y 5m 30d Gender: Male Location: Adelaide Posted 04/12/14 03:38 AM Share Posted 04/12/14 03:38 AM that's because numpkins "think" it looks ok but its not Visual inspection can catch out some people Push up on the tailshaft by the CB and it should only flex the rubber coupling a tiny bit, if u get +10mm on it shes no good and that's what thumps under load but only at certin speeds Link to comment Share on other sites More sharing options...
rollex Member 683 Member For: 10y 5m 22d Gender: Male Location: Australia Posted 04/12/14 05:11 AM Author Share Posted 04/12/14 05:11 AM Yeah its really mild now because the diff doesn't move any more but it is still knackered. I'll take it to a local mechanic, sick of driving that far.Cheers Link to comment Share on other sites More sharing options...
rollex Member 683 Member For: 10y 5m 22d Gender: Male Location: Australia Posted 23/02/15 11:09 PM Author Share Posted 23/02/15 11:09 PM (edited) Had two workshops look at this and give up. Diff bushes are new, centre bearing has zero play. They tightened up a bunch of loose stuff (subframe bolts and vibration shield) which didn't fix it. Suggested it could be driveshaft/tailshaft bearings but they didn't want to start replacing stuff hoping it would fix it in case it wasn't the problem. Said it might be best just waiting for it to get worse until it becomes obvious what it is. They didn't charge me as they couldn't figure it out. Edited 23/02/15 11:11 PM by rollex Link to comment Share on other sites More sharing options...
JETURBO ...JD TUNING ADELAIDE... Gold Donating Members 23,708 Member For: 16y 5m 30d Gender: Male Location: Adelaide Posted 24/02/15 01:22 AM Share Posted 24/02/15 01:22 AM LoL Just change the CB its cheap ffs Link to comment Share on other sites More sharing options...
BenDoCo I'm getten too old for this s**t Bronze Donating Members 4,509 Member For: 11y 7m 23d Gender: Male Location: A big bridge over a river in South Australia Posted 24/02/15 01:30 AM Share Posted 24/02/15 01:30 AM Didn't you mention the center bearing a while back? Link to comment Share on other sites More sharing options...
JETURBO ...JD TUNING ADELAIDE... Gold Donating Members 23,708 Member For: 16y 5m 30d Gender: Male Location: Adelaide Posted 24/02/15 01:33 AM Share Posted 24/02/15 01:33 AM What would I know Link to comment Share on other sites More sharing options...
