Removal Of Clutch Line From Slave With Gearbox Still In Car? Help?
psi355nos
  • Inactive Members
  • Member For: 10y 4m 9d
Hi, I am after some help on how to remove the clutch fluid line from a BF 6speed manuel. Can be removed from master cylinder side easily but unsure on how to remove it from off the slave cylinder inside the bellhousing whithout pulling the box out? I am thinking maybe there is a specialist tool like a crows foot 90degree socket or something? Surely someone has done this before? or can the line be removed at another location? Thanks
  • The Toxic Rocket
  • Member For: 14y 11m 13d
I think you'd be doing well to remove it whilst still connected. What you could do though is remove the 6-8 bolts holding the gearbox to the bell-housing and slide the gearbox back 10cm or so and get two spanners in there.
