feetandass Member 17 Member For: 9y 10m 26d Gender: Male Posted 28/11/14 03:45 PM Share Posted 28/11/14 03:45 PM Hey all! Ive recently bought a BF MK2 XR6 Turbo and intermittently the indicators will not cancel upon straightening the wheel. Has anyone else experienced this? How did you go about fixing it? Please help!!!!!! Link to comment Share on other sites More sharing options...
rokkie Member 87 Member For: 12y 1m Gender: Male Location: Adelaide, SA Posted 28/11/14 11:07 PM Share Posted 28/11/14 11:07 PM Hey, if the previous owner had the combination switch changed the indicator cam may have been fitted incorrectly. To fix it you will have to remove the steering wheel and clock spring. There should be a white plastic cam with two flat cut outs. These cut outs should line up with the steering shaft. If not it may be damaged. We used to keep all the old switches and swap the cams over. Link to comment Share on other sites More sharing options...
