Bizkets is Drunk? Too heavy needs boost Member 5,929 Member For: 11y 10m 11d Gender: Male Location: Adelaide Posted 15/09/15 02:34 PM Share Posted 15/09/15 02:34 PM On 15/09/2015 at 12:45 PM, norrs said: Yes it appears so is that a problem. It's was apparently $98 of oil$98 bucks. What did they put in. Give you six and charge you for ten. Rip off. Can you service it yourself. Link to comment https://www.fordxr6turbo.com/forum/topic/89644-fg-xr6t-aircon-is-rubbish/page/6/#findComment-1561760 Share on other sites More sharing options...
norrs Donating Members 448 Member For: 17y 10m 25d Gender: Male Location: Darwin Posted 15/09/15 08:35 PM Share Posted 15/09/15 08:35 PM Yes I can but I have an aircon problem that they were to diagnose. And we'll, they didn't Link to comment https://www.fordxr6turbo.com/forum/topic/89644-fg-xr6t-aircon-is-rubbish/page/6/#findComment-1561762 Share on other sites More sharing options...
PTR_NITRO_FG Donating Members 3,214 Member For: 12y 22d Gender: Male Location: NOR Perth Posted 16/09/15 02:36 AM Share Posted 16/09/15 02:36 AM 1) confirm whether the job card actually said 5W 30....I've had it (and seen it before) where the invoice is wrong, but their job card has correct info. If they did, ask them why and tell them to f*ck off and put the right oil in (pretty sure hotter would need higher second number I.e. should have put 15W 50 if the heat was a factor? manual should say 15W 40)2) 444CCA battery is not "ultra high performance"....if Ford sold you both at the same CCA, they are dodgy dealership and I would change (unless you have warranty or something?). Mines 460 CCA and that's a cheapie battery....you need around 600 CCA (I think the ones I looked at were 660)But yeh sucky about the AC not working....could always try another AC specialist if theres one in Darwin? (you'd think there would be heaps cause always hot) lol they may charge less than Ford for 'diagnostic' work....I have aftermarket warranty....but purposely mainly use them for the scheduled servicing only. When sh*t breaks, I try and outsource to other businesses who specialise in the issue (cause Ford often outsources their work when they have NFI). 1 Link to comment https://www.fordxr6turbo.com/forum/topic/89644-fg-xr6t-aircon-is-rubbish/page/6/#findComment-1561828 Share on other sites More sharing options...
norrs Donating Members 448 Member For: 17y 10m 25d Gender: Male Location: Darwin Posted 16/09/15 09:15 AM Share Posted 16/09/15 09:15 AM Well they did the oil change yesterday and I could hear an odd noise when I drove away from the dealership. Comes on when I hit throttle. Anyway sounds worse today I just got home and the turbo is f*cked! I can only just turn it with my fingers and it makes a grinding noise. I had no noise after shut down prior to this WTF!!! Link to comment https://www.fordxr6turbo.com/forum/topic/89644-fg-xr6t-aircon-is-rubbish/page/6/#findComment-1561948 Share on other sites More sharing options...
PTR_NITRO_FG Donating Members 3,214 Member For: 12y 22d Gender: Male Location: NOR Perth Posted 16/09/15 09:21 AM Share Posted 16/09/15 09:21 AM Legit? You have an earls turbo line filter yeh?No good dude...sounds like turbos about to poo itself :( Link to comment https://www.fordxr6turbo.com/forum/topic/89644-fg-xr6t-aircon-is-rubbish/page/6/#findComment-1561951 Share on other sites More sharing options...
norrs Donating Members 448 Member For: 17y 10m 25d Gender: Male Location: Darwin Posted 16/09/15 09:28 AM Share Posted 16/09/15 09:28 AM Yep just checked earls and it was not blocked!! Link to comment https://www.fordxr6turbo.com/forum/topic/89644-fg-xr6t-aircon-is-rubbish/page/6/#findComment-1561954 Share on other sites More sharing options...
discostig Manual mode ________________________ All day, erryday Donating Members 13,798 Member For: 17y 6m 23d Gender: Male Location: Probably above atmospheric pressure Posted 16/09/15 11:52 AM Share Posted 16/09/15 11:52 AM Fark...think they flogged it cold and shut it down hot? 1 Link to comment https://www.fordxr6turbo.com/forum/topic/89644-fg-xr6t-aircon-is-rubbish/page/6/#findComment-1561985 Share on other sites More sharing options...
norrs Donating Members 448 Member For: 17y 10m 25d Gender: Male Location: Darwin Posted 16/09/15 09:09 PM Share Posted 16/09/15 09:09 PM I have a car cam, I'll check Link to comment https://www.fordxr6turbo.com/forum/topic/89644-fg-xr6t-aircon-is-rubbish/page/6/#findComment-1562005 Share on other sites More sharing options...
norrs Donating Members 448 Member For: 17y 10m 25d Gender: Male Location: Darwin Posted 16/09/15 09:40 PM Share Posted 16/09/15 09:40 PM Checked it and it appears to have been disconnected but them. Anyway, I'm certainly not going to blame ford without evidence. Just a coincidence I suppose. Link to comment https://www.fordxr6turbo.com/forum/topic/89644-fg-xr6t-aircon-is-rubbish/page/6/#findComment-1562008 Share on other sites More sharing options...
discostig Manual mode ________________________ All day, erryday Donating Members 13,798 Member For: 17y 6m 23d Gender: Male Location: Probably above atmospheric pressure Posted 16/09/15 11:55 PM Share Posted 16/09/15 11:55 PM Bugger. Link to comment https://www.fordxr6turbo.com/forum/topic/89644-fg-xr6t-aircon-is-rubbish/page/6/#findComment-1562023 Share on other sites More sharing options...
