Fg Xr6T Aircon Is Rubbish
  • Member For: 10y 4m 20d
Hi all just a question about fg ac.
Our fan when putting it on semi auto and turning it right up to full blast still has no pressure when blowing the air out, and the ac takes ages to cut in and when it does its intermittent. Woukd the him module be buggered or is there another reason its ordinary
Regards kane
  • Member For: 11y 8m 2d
my car suffers the same ....
replaced him..
new battery
re gassed
and still has issues
other things to check are the ambient temp sensor in the left hand mirror
and also update the icc so the compressor stays on longer ..
that's all I got at the moment
  • All stock bar the k&n panel filter
  • Member For: 12y 9m 22d
I found a big difference in the ability of the AC in my FG MK1 XR6T compared to that of my FG MK2 GT. MK2 aircon is much more capable.
  • Member For: 17y 1m 11d
MY BFII air con is so cold it makes my knuckles hurt.
  • Member For: 13y 11m 26d
Mines perfect and I have an FG (there's no such thing as a mk1!).
Fans great, airs freezing cold, got no problems. Even accidentally let a bit of gas out when I did my first coolant drop, only a small amount though. Stock power.
  • Like 2
  • Member For: 12y 7m 8d
I have a low KM FG Pre-facelift, but Euro4 model. The fan blows hard on max without a problem, it does take a while for the fan to ramp up after climate control is activated after being turned off, no big delay at all.
The problem was with how cool the vent temperature got on warmer days.
I took it to the master technicians at my Ford dealer to perform checks on any common problems, modules, sensors etc, all which were confirmed to be working fine.
However the vent temp was still substandard at many times, still cool to do the job but the best way to describe it would be "cold enough to say it has A/C". So after confirming the car had no been leaking refrigerant, I removed the R134a and re-gassed it with R290/R600a (Hychill), it is now very cold on a 35 degree day.
