Engine Rattle
ullysses
  • Member For: 14y 3m 21d
Ive run ford mineral 15w-40, 5w-40 synthetic havoline, nulon 10w-40 full syn, 10w-40 penrite racing and 15w-40 semi syn penrite and never had a single noise period. I run the penrite racing 10w-40 exclusively know and its as quiet as a mouse.
  • Member For: 14y 4m 7d
I guess everyone has their own reasoning and justifications. All I know the ford engineers have specified a certain grade of oil. I've had Agee of these things apart,and ican tell you the tolerance leave slot to be desired.
Ill give an example. If Ferrari asks for a 0 whatever .. Would you listen to your tuner if he specified a 20w-60 ????
Cheers
  • Member For: 12y 3m 29d
What oil you run Jimmy? I run the Nulon 10w-40 and have spoken with the nulon tech guys a few times and they recommend I step up to the 15-50 for the circuit days I do, so will be doing that before the next one.
I change under every 5000km, or for every track day. Oil is cheap.
  • Member For: 10y 10m 28d
I never liked nulon oils ,also you will find it hard to find (15w-50 ) most shops do not stock it . I just use penrite racing 15-50 but next time will get the even heavier 60 oil . mine is a old
ba engine with 110,000 klm on the clock
oils are like cars everyone likes one brand more than the other . lol oil is oil as long as you change it regularly it will be fine no mater what brand you use
Edited by gunna
  • Like 3
I'm running pen rite racing 15-50
I'm just more curious as to what the argument is about running a lighter oil in the barra. What the logic is?
I'd be more inclined to listen to a"tuner's" recommendation if he'd actually built a barra or 10.... Not just tuning
As I stated before,tolerances in the ol barra leave alot to be desired. A heavier weight oil can only aid..not hinder.
  • Like 2
  • Member For: 14y 11m 8d
You've got to remember that the 0w40 and a 10w40 are the same weight at normal operating temps. A 0w is actually closer to the 40 requirement that the engineers who design the vehicle want at operating temp.
Running a higher end number is if you flog it enough that the higher operating temp you have makes that higher number act the same as say a 40 at normal operating temp.
So generally the first number isn't going to make a huge difference, but the quality and brand can.
Oil is bloody hard to get right and each to their own really. I run a 5w40 and no issues at all.
my oil pressure dropped right down to about 5 psi after puling in from every powercruise event . so now that it is getting hotter I will up the oil viscosity so that I do not have the same
problems . it is not a daily driven car ,only weekends
  • Member For: 17y 1m 2d
Make sure your oil pressure reading is accurate though. I'm dubious on mine as it's taken from a sandwhich plate under the oil filter.
Anyone able to confirm if this would be an accurate location to take readings from as compared to what's actually up in the pump?
  • Carnage on the Garage Floor
  • Member For: 14y 7m 15d
Must say the common theme seems to be people running heavier springs too. I do remember Brad from Atomic telling me something about that.
