genx2g Member 95 Member For: 11y 7m 30d Posted 12/11/14 09:15 AM Share Posted 12/11/14 09:15 AM Hey guys, serious post. my cars been ******* up lately, its a 2008 g6et.as soon as the car is put under load (usually when boost starts to kick in) it starts to lose power and misfire. I changed the coils today, no such luck... anyone have any ideas or usefull advice on what it is/ what I should do? Link to comment https://www.fordxr6turbo.com/forum/topic/89568-g6et-misfirelosing-power/ Share on other sites More sharing options...
MattyP MattyP Cruise Control 6,317 Member For: 13y 1m 15d Gender: Male Location: Central Coast Posted 12/11/14 09:20 AM Share Posted 12/11/14 09:20 AM Is it tuned? Link to comment https://www.fordxr6turbo.com/forum/topic/89568-g6et-misfirelosing-power/#findComment-1511858 Share on other sites More sharing options...
genuine honest person Member 2,769 Member For: 11y 4m 22d Gender: Male Location: near brisbane Posted 12/11/14 09:25 AM Share Posted 12/11/14 09:25 AM petrol filter ? Link to comment https://www.fordxr6turbo.com/forum/topic/89568-g6et-misfirelosing-power/#findComment-1511859 Share on other sites More sharing options...
NVT Formerly EGOBFXR6 Donating Members 1,111 Member For: 17y 4m 14d Gender: Male Location: Perth, WA Posted 12/11/14 10:06 AM Share Posted 12/11/14 10:06 AM (edited) Hi mate,Do the cheap/free/easy stuff first to try and solve it;Are you using the right fuel for the car/tune? (95/98 etc)Is it old fuel? A bad batch perhaps?Replace your fuel filterPut a fuel system cleaner through the carCheck and clean your air intake filterCoil packs (as done) - are they genuine? Genuine are highly recommended Fouled spark plugs - Good brand gapped correctly for your applicationBoost leaks? Check your piping/clamps/hoses etcCheck turbo for excessive play/bent fins/excessive oil etcI'd also be checking your drive belts/oil levels and condition/general component inspectionCould be an issue with the Throttle body/TPS?Hopefully you will have some luck with one of the above.If it's still horrible, instead of wasting (lots) of money guessing, take it to a reputable shop mate - It'll save you time and money if the cheap/easy options don't work...Cheers and good luck,Dan Edited 12/11/14 10:08 AM by NVT Link to comment https://www.fordxr6turbo.com/forum/topic/89568-g6et-misfirelosing-power/#findComment-1511869 Share on other sites More sharing options...
