  • Member For: 14y 8m 9d
No Idea what n/a tolerances are. But I do know a lot of LS1 applications actually run a interference fit of 1thou !!!
That's why its imperative that a torque is used when machining. I had one made at great expense..
  • Bronze Donating Members
  • Member For: 13y 9m 7d
  On 05/11/2014 at 1:02 PM, FORCEDG6E said:
I just hope my machinest knows what hes doing about all this becuase im lost
They just machine to a nominal bore diameter so its pretty hard to mess up.The bore to wall clearance is built into the piston itself. Looking at my paper work Ross recommend a 5 thou clearance. That's why they rattle.
  • Member For: 17y 8m 10d
Clearance depends on the type of alloy used. 4032 expands less so you can run tighter clearances. 2618 expands more so needs more clearance but generally are said to handle more. I see that the Ross units are made from 2618.
