  • Member For: 11y 7m 15d
Mine had 3 welded sections. I used a rotary tool with a cut off wheel and cut through most of the weld, then used a hammer and big screwdriver to knock the ring in. Then just pulled it out.
  • 3 weeks later...
  • Member For: 12y 3m 3d
Worked a treat thanks for the tip
  • 2 weeks later...
  • Member For: 12y 4m 27d
Venom high flow cat for mk1 bash out ring in factory cat mk2 I believe. So you are fine if you have venom cat
