  • Member For: 11y 5m 3d
Torque uses the ford specific pid, converts from kpa(maybe hpa?) to psi in the formula. Should be the same readings the pcm is getting so you would hope its accurate
  • New Member
  • Member For: 10y 5m 26d
Does anyone else's boost show a constant 5.5 psi?
I tried playing around with the boost settings where it suggests -14.7 or 0 or 14.7 but doesn't seem to change anything..or is it just a ford thing?
Also is it worth getting a 2nd OBD for iOS? I have a "ELM327 Super-mini OBD2 Bluetooth"
But it doesn't work on iOS. I've had to ninja my sons Android but droid tablets feel so laggy.
- Are you guys using Androids or iPhones?
  • MattyP
  • Cruise Control
  • Member For: 12y 11m 19d
Android the lazy one.. Please...
I've noticed that there isn't a delay greater than 1/2 sec in throttle position but the boost one I was unsure off what it was doing
Like on my e85 tune (20-21psi) would occasionally only hit 18 but then sometimes it would go to 24.
Hope it's just torque being silly
  • Member For: 18y 1m 17d
  On 03/11/2014 at 11:08 AM, Peppy_t92 said:
Innovate OT-2 for iOS
I've got one of those!!! they work pretty good. The virtual dyno was pretty cool.
