TURBO07 Member 3 Member For: 12y 1m 28d Posted 30/10/14 05:53 AM Share Posted 30/10/14 05:53 AM Hi everyone,I'm new to turbo cars but am fairly sure that there is a leak due to one bolt missing as evident in the photos attached. Guessing it's the bolt going from rear housing..?What effects does this have? Power? Economy?How hard is it to fix this DIY and how much of a job is it?Any help is appreciated Link to comment https://www.fordxr6turbo.com/forum/topic/89479-bolt-missing-please-help/ Share on other sites More sharing options...
Macy New Member 20 Member For: 15y 7m 19d Gender: Male Posted 30/10/14 10:24 AM Share Posted 30/10/14 10:24 AM Painful spot to lose a stud, you may be able remove nut from another stud and size it up at a fastener shop or go to Ford. put it up on car stands and get your hands dirty. use high temp Loctite and let it set overnight. All the nuts on turbo, manifold, need to be inspected regulary. Its not uncommon to lose bolts on exhaust side, these parts glow. It wont cost you that much I imagine. Link to comment https://www.fordxr6turbo.com/forum/topic/89479-bolt-missing-please-help/#findComment-1509229 Share on other sites More sharing options...
TURBO07 Member 3 Member For: 12y 1m 28d Posted 30/10/14 03:20 PM Author Share Posted 30/10/14 03:20 PM Thanks mate, it was a pain to spot and looks like it's going to be even harder to fix. I can only just get my finger behind there to feel that it's missing. Link to comment https://www.fordxr6turbo.com/forum/topic/89479-bolt-missing-please-help/#findComment-1509266 Share on other sites More sharing options...
gregaust Member 48 Member For: 21y 7m 3d Gender: Male Location: QLD Posted 31/10/14 08:12 PM Share Posted 31/10/14 08:12 PM Is it missing or broken off? Missing then you're lucky. Just fit another stud or a bolt even would work. Pretty sure they are 8x1.25. Link to comment https://www.fordxr6turbo.com/forum/topic/89479-bolt-missing-please-help/#findComment-1509485 Share on other sites More sharing options...
