Surge Tank + Fuel Pump, When Do You Need Them And Why?
  • Member For: 19y 6m 5d
  • Member For: 10y 10m 19d
I wonder how using a speed controller would adjust both of those curves, if it would be just a little or a large difference.
Edited by rollex
  • RNS10S
  • Member For: 18y 8m 11d
  On 30/10/2014 at 4:08 AM, KPM Motorsport said:
Fuel Temperature Test Video
Cick on link:
https://www.youtube.com/watch?v=vnduB5iSM-U&feature=youtu.be
From AFF thread
Originally Posted by rednose
This morning we started with 6/8th of a full tank, fuel temp 20C, ambient temp 23C.
Drove 50klms to work in stop start traffic and arrived with fuel temp at 38C, ambient temp of 24C
The drive to work at this time normally takes around 1hr and 10 mins.
In your test the fuel temp of the surge setup went past 38C in less than 30mins with a lower ambient temp......
Similar conditions but Pump controller was switched off, so the noisy A1000 was pumping hard !!!
Started with 1/2 tank, fuel temp was 20C, ambient was 22C, arrived at work with fuel temp at 45C, ambient temp on arrival was 22C
This one is with the controller off, still took over 30 mins to get to 40C and again, ambient temp was higher in my test and I'd bet my pump is higher flowing.......
Edited by rednose
  • Member For: 13y 2m 18d
I don't know why this conversation keeps going on... As I see it:
- If you can't afford it, buy an external surge and put up with noise, hotter fuel and cheaper prices.
- If you can afford it, pay the expense and have a quiet system that looks to not heat the fuel as much.
Results at the end of the day mean that your car has a much less likelyhood of blowing up using either system.
As for the discussion on 044's.... Well....
I think they've got their place in the market but let's be honest how can anyone refute the manufacturers statement about how they are only built to withstand 500hrs on E85?
I think that Bosch know their product, and no workshop in the world can convince me that "she'll be right to set and forget mate". Seriously... Just because a few of you have used them for a few years on E85 now makes your claims superior to a multi-billion dollar OEM manufacturer?
I know I'd not be using an 044 on E85
Edited by demon1300
  • Member For: 18y 11m
The questions of the testing are the reason I posted in the intercooler thread that any testing should be done by an independent third party, people asked for KPM's testing data, possibly thinking it did not exist and now want to question it, not just on this forum but others as well
I think its obvious that KPM know what they're doing. Any smart proprietor would be foolish to make claims about their products that are unsubstantiated. You would risk your business name and credibility...
They obviously have not a lot to gain by doing it, considering its such a small market, but a whole lot to lose if their claims are bogus.
Edited by demon1300
  • WOT?
  • Moderating Team
  • Member For: 12y 2m 2d
I'm tipping that the stationary car on the dyno would be heating up quicker than one on the road with airflow having a cooling effect on the surge.
  • RNS10S
Mick are you saying we shouldn't question the results???
If you had conducted the test would you have different fuel temp starting points???
Not saying this at all, but knew coming from KPM it would get disputed from some, which again is why I recommended a third party to test it.
If I was to test a system, I may not have any control over the initial fuel temp, if a car has been started the fuel will be above ambient temp
