Surge Tank + Fuel Pump, When Do You Need Them And Why?
  • Member For: 19y 7m 25d
Pctured above is our Streetfighter 1000Hp Intank system utilising our previous 300lph Fuel pumps.
As pictured below we now have a new 300 Lph fuel pump that has been developed and rated on constant E85 usage for 10,000 hours.
Our previous pumps , were rated at 500 hrs on E85.
  • Silver Donating Members
  • Member For: 12y 2m 13d
I'm happy to throw two of your new e85 pumps into my module, along with your 1500cc injectors and prove that it can make over 500rwkw?
  • Dropping a turd
  • Member For: 17y 7m 20d
  On 23/10/2014 at 11:54 PM, KPM Motorsport said:
Streetfighter1000HpTwinIntankPumpModulev
Looks similar to what Nizpro developed in 2006. They used an In tank single 044 But they filled the inside of the tank with foam to baffle the fuel surge / slosh.
I still like the idea of a surge. Swirl pot may give 11-13 seconds but I also have the nearly 2 litres in the surge tank as well
Anyrate running a high boost car with under a 1/4 tank of fuel is stupid.
Edited by arronm
The swirl pot has 1.5 litres however it refills and stays full of cooler dense fuel at a rate that fills it quicker than can be used at the engineered power levels. When we use the empty fuel tank scenario this is to show the extreme cabability at a rated power level..
  • Bronze Donating Members
  • Member For: 11y 11m 15d
I think the bottom line in this is KPM have designed, engineered, tested and back their product through the work they've done. If you feel you need to sleep easier at night sure buy the surge, but it's still not a silver bullet to some of the problems here
After going to the KPM evening at pitlane, I've budgeted for a intake setup from them
  • Like 2
