Huge Project! Im Swapping Over Everything From An Xr6T Into A Ba M
ERICtheBERIC
  • 4 weeks later...
  • Member For: 10y 5m 2d
So I had an auto sparky out a few times, and he has checked all the fuses, relays, etc, etc and found no fault. The problem apparently comes from when he tries to code the key to the BCM, the BCM is not recognising the key being there. It cycles the door locks, but won't actually read the key being there. We tried to program the original BCM (with the whole ICC) with it's matching barrel and key and key reader, and still nothing. (this is all with the turbo ECU installed). I have measured the continuity of the wires from the key reader to the plug that goes into the BCM and they're all fine. We tried to code the key in again with all the gear from the turbo car again (key barrel ,key reader, BCM) and it still doesn't register a key being there. He said last resort was to get the key transponders tested, I haven't done that yet but seems pretty unlikely. Im pretty stuck as to what to do, but I've read on other forums that apparently I need to take the car to ford and they will be able to fix it. Does this sound about right? Im all out of other ideas, and the sparky I had out was pretty knowledgable about the car. Any help would be greatly appreciated
  • Member For: 11y 10d
Ford did not even want to help me when I had the problem with the abs module ,barnz worked that one out for me . but give Ford a phone call and see what they have to say. sorry to hear that you have problems with it . ps (picture ) that black strip of rubber and steel is a mounting bracket for the bottom hot side intercooler hose (near the radiator )
  • Member For: 11y 2m 18d
This is strange coz if absolutely everything was swapped including column and keys then no coding should be required and the car should essentially just wake up in a new body.
Was the xr6t stolen before becoming a wreck?
  • Spooling Member
  • Member For: 13y 2m 1d
Give us a list of all the modules / electronics you have replaced. I recently swapped all modules etc between 2x FGs and the last piece of my puzzle came down to the steering coloumn.
Cheers gunna, appreciate it! Literally all the electrics are from the turbo car, including both fuse boxes, same thing with steering column, dash, etc. The car had never been stolen, but it did have an aftermarket alarm system installed which I threw out. All the wires coming to it were spliced in, so theres no discontinuities in the wires after I removed it (Im pretty sure). I took a video of what happens when I try and start it, maybe itll clear some things up.
Just having a look behind the fuse box, I found what looks like a diode (?) among the wires that go to the diagnostic plug
Could somebody tell me if that's stock? Other than that im all out of ideas, and am completely heartbroken.
