ERICtheBERIC Member 105 Member For: 10y 5m 7d Gender: Male Location: Perth Posted 11/08/15 06:59 AM Author Share Posted 11/08/15 06:59 AM I'm having a bit of trouble with the brake lights staying on, cause the pedal doesn't reach the light switch in its normal return position. which is super weird as it worked fine in the other car I played with the 10mm bolt that adjusts the angle of the plate with the switches, but in its maximum position it still doesn't reach the switch. I also put in a little white shim that was on the auto pedal box brake pedal and still nothing. Would I be alright to just raise the height of the brake pedal flange bit that actuates the switch with superglue or just tape or something? or is this a sign of something else that's wrongthanks Link to comment Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,323 Member For: 19y 4m 19d Gender: Male Location: Perth Posted 11/08/15 07:13 AM Share Posted 11/08/15 07:13 AM The switches need to be reset before installing them, You need to push the switch plunger in and then twist the two tangs above the lock tabs so they line up with the lock tabs. When you install the switch and twist it the plunger will pop out and contact the pedal and thus set the length. 1 Link to comment Share on other sites More sharing options...
ERICtheBERIC Member 105 Member For: 10y 5m 7d Gender: Male Location: Perth Posted 11/08/15 08:38 AM Author Share Posted 11/08/15 08:38 AM I gave that a go, but nothing wants to turn. the lock tabs and the tangs seem to be made of the same bit of plastic if I'm not mistaken. Link to comment Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,323 Member For: 19y 4m 19d Gender: Male Location: Perth Posted 11/08/15 08:47 AM Share Posted 11/08/15 08:47 AM Is that a ba switch?is so plunger should ratchet out. You hold the pedal down,install the switch and it sets the height when you release the pedal Link to comment Share on other sites More sharing options...
ERICtheBERIC Member 105 Member For: 10y 5m 7d Gender: Male Location: Perth Posted 12/08/15 11:22 AM Author Share Posted 12/08/15 11:22 AM yea spot on mate, I just pulled on the plunger and it came out. cheers Link to comment Share on other sites More sharing options...
ERICtheBERIC Member 105 Member For: 10y 5m 7d Gender: Male Location: Perth Posted 12/08/15 11:28 AM Author Share Posted 12/08/15 11:28 AM yea spot on mate, I just pulled on the plunger and it came right out, cheers for that Link to comment Share on other sites More sharing options...
ERICtheBERIC Member 105 Member For: 10y 5m 7d Gender: Male Location: Perth Posted 01/09/15 11:02 AM Author Share Posted 01/09/15 11:02 AM first go over pits, heres the listI replaced the main diff bush literally less than 100 kms before I took it to the pits with a nolathane one and it was cracked the whole way through by the time I got there. What a piece of crap, im guessing the other obvious choioce would be super pro, still means ive gotta take the whole IRS out again arrgggghhhhh. The rust is pretty minor I think the guy was just being a dick there but I got a quote for 200 which is mintt. Other than that its pretty simple, should be ready in a couple weeks time! heres what she looks like now sitting in my driveway Link to comment Share on other sites More sharing options...
PTR_NITRO_FG Donating Members 3,214 Member For: 11y 8m 17d Gender: Male Location: NOR Perth Posted 02/09/15 04:02 AM Share Posted 02/09/15 04:02 AM another soon to be XT sleeper good to see you're almost there! well done 1 Link to comment Share on other sites More sharing options...
masda74 To Loud Gold Donating Members 4,112 Member For: 13y 2m 12d Gender: Male Location: WA, Perth Posted 03/09/15 12:33 AM Share Posted 03/09/15 12:33 AM Hoping that most stuff has been resolved. what have you done with the diff bush though?Have you put something else in there? 1 Link to comment Share on other sites More sharing options...
ERICtheBERIC Member 105 Member For: 10y 5m 7d Gender: Male Location: Perth Posted 17/09/15 02:31 AM Author Share Posted 17/09/15 02:31 AM Yep I put in a super pro bush, its outlasted the nolathane one already. Finally passed the pits yesterday, went and got my number plates, drove to a mates house and the clutch promptly shat itself. Lost all feel and couldnt get any gears. So I had to get a tow out to dads workshop where itll be sitting until I can get a new clutch. Absolutely spewing! What would you guys reccomend for a clutch kit? Its just a stock xr6t and im trying to spend as little as I can Link to comment Share on other sites More sharing options...
