  • Member For: 14y 3m 20d
Before anyone says tremec makes the gearbox they should know.
It's bs. I tried the g70 additive with dex111. Did nothing maybe worse. But definitely no improvement. Tried the penrite 70w 75 as recommended on their site. Fn expensive. $140 for 5 ltrs. But it fn works. Roll over completely gone. Sincros work quicker.
I rebuilt the box about 2 months ago. New bearings and seals. Typical usa design. Big ass gears. Looooooose tolerance gear mess. The rollover was the same rven when completely rebuilt. Finally it doesn't soung like a truck idling when the aircon is on.
  • Like 3
  • All stock bar the k&n panel filter
  • Member For: 13y 1m 25d
  • Member For: 13y 8m 28d
Hmmmmm interesting.
I have a t56 and some days with the ac on it sounds like a truck lol
I just serviced it with the oil it suggested, dex lll
It says to stay away from synthetic oils?!?!?! I have a smal grind from 2-3 and it's noisy at idle a little..... Think oil would help it?
Actually that is a point...my rollover in my XR6T was pretty non existent when I had Mainlube in it, but then old mate Slacko went and changed it out for some redline oil and it was noisy as fark! Don't think I ever ground second with the Mainlube in the box either actually, come to think of it...
Edited by .Stripes.
  • less WHY; more WOT
  • Site Developer
  • Member For: 17y 28d
http://www.castrol.com/en_au/australia/products/truck-and-bus/automatic-transmission-fluids/transmax-z.html
http://www.castrol.com/en_au/australia/products/cars/automatic-transmission-fluids/transmax-multivehicle.html
They are definitely different. The Multivehicle is just a Dexron3 specification oil.
If you want to find where Transmax Z is stocked, you can call 1300 557 998 and ask them where the nearest distributor is.
Edited by k31th
