rollex Member 683 Member For: 10y 8m 15d Gender: Male Location: Australia Posted 12/10/14 08:07 AM Share Posted 12/10/14 08:07 AM (edited) Can you remap the pedal throttle position vs actual throttle position on these cars? Eg make 10% throttle actually open the throttle by 20% so it doesn't feel so doughy?Is there any way you could make a 2d map with throttle position vs actual throttle servo opening, how is it done out of the factory, a 1:1 mapping? Does it limit the actual throttle position if you floor it at 1krpm in 6th or will it still open the throttle 100% if you flatten it? Edited 12/10/14 08:09 AM by rollex Link to comment Share on other sites More sharing options...
JETURBO ...JD TUNING ADELAIDE... Gold Donating Members 23,708 Member For: 16y 8m 24d Gender: Male Location: Adelaide Posted 12/10/14 08:20 AM Share Posted 12/10/14 08:20 AM Yes u can Link to comment Share on other sites More sharing options...
rollex Member 683 Member For: 10y 8m 15d Gender: Male Location: Australia Posted 12/10/14 08:23 AM Author Share Posted 12/10/14 08:23 AM Do people commonly do it to make the throttle feel less doughly? I swear my 900cc charade feels like it has more torque at 5-10% throttle. Link to comment Share on other sites More sharing options...
JETURBO ...JD TUNING ADELAIDE... Gold Donating Members 23,708 Member For: 16y 8m 24d Gender: Male Location: Adelaide Posted 12/10/14 09:05 AM Share Posted 12/10/14 09:05 AM Its common for stock 4mtr long inlet tract Get modding Link to comment Share on other sites More sharing options...
rollex Member 683 Member For: 10y 8m 15d Gender: Male Location: Australia Posted 12/10/14 09:24 AM Author Share Posted 12/10/14 09:24 AM Not really sure what you are saying, start modding the ecu? Link to comment Share on other sites More sharing options...
JETURBO ...JD TUNING ADELAIDE... Gold Donating Members 23,708 Member For: 16y 8m 24d Gender: Male Location: Adelaide Posted 12/10/14 09:54 AM Share Posted 12/10/14 09:54 AM No reduce the inlet tract with common cooler kits and turbo side intakes Stock "lag" isnt lag its actually the distance until boost hits Link to comment Share on other sites More sharing options...
Kimberley Scott www.australianflag.org.au Donating Members 6,763 Member For: 19y 7m 7d Gender: Male Location: Brisbane Posted 12/10/14 10:00 AM Share Posted 12/10/14 10:00 AM Um push throttle harder. Not being a smart ass. But cheaper than playing with ECU. Link to comment Share on other sites More sharing options...
Peppy_t92 Silver Donating Members 748 Member For: 11y 10m 21d Gender: Male Location: Liverpool Posted 12/10/14 10:36 AM Share Posted 12/10/14 10:36 AM I have played with it on the turbo6, more trouble then it's worth... It takes very fine adjustments, more like 1-5%, definitely not 10% or 20%, and will go into limp mode occasionally if it's not right... It is done on the coyotes to give them full throttle, but their OS has the ability to turn up the thresh hold of the limp mode error 1 Link to comment Share on other sites More sharing options...
rollex Member 683 Member For: 10y 8m 15d Gender: Male Location: Australia Posted 13/10/14 12:30 AM Author Share Posted 13/10/14 12:30 AM No reduce the inlet tract with common cooler kits and turbo side intakesStock "lag" isnt lag its actually the distance until boost hitsI'm just talking about off boost performance, eg 1500-2000rpm etc, my old 2.5L felt like it had better off boost performance, though if I flatten it at 2k it feels fine, just feels like it needs more throttle than it should being a big 4LThe boost lag feels normal for a turbo car with a turbo that size, eg not coming on until about 3k. Link to comment Share on other sites More sharing options...
discostig Manual mode ________________________ All day, erryday Donating Members 13,798 Member For: 17y 2m 30d Gender: Male Location: Probably above atmospheric pressure Posted 13/10/14 05:05 AM Share Posted 13/10/14 05:05 AM Low compression engine (to suit turbocharging) means laggier off boost performance, pretty sure that's the cause. NA XR6s are snappier off the line, unless you stall it up yourself to build boost, for example. Link to comment Share on other sites More sharing options...
